  • Replies 160
I got a demon hunter level 33 in nightmare mode and his gettin owned so I've decided to make a monk and I love it..did I make a right choice? I don't want to make a wizard coz everyone's practically got one
all it takes is one lag spike and then bye bye :)
Your dead on with this one. Once every two days i will get a bad connection and the lag kicks in.I am still yet to complete normal mode (nearly at end of act 3) but it would be impossible with hardcore mode to get anywhere with lag.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
