Only grabbed one caliper out of the packaging for pics, but is enough to see the general condition of the kit. Rotors are in good condition, though there is a concentric wear mark on the insides of the rotors, but nothing to be concerned about
Gizzmo Launch Interface (IGN Cut), Gizzmo Dual stage Shift Light, Adapter Loom for RB25 $300 ono
Alcon Mono6 calipers $2400 firm
Genuine Trust T67-25G $1800 firm
Genuine Trust TD06H-25G turbo $1650 firm
Genuine NEW Tomei 82mm RB24 pistons $1150 ono
Tomei RB20DET Poncams $700ono
Tomei RB20DET / VG30DETT Valve Spring $300 ono
Volk 17" GT-P rims $1000 ono
Brembo F40 R32/33 kit $1950ono
Koyo R32 GTR replacement radiator $300ono
Rebuilt with forged internals R32 RB25DE $1700 ono
R33 RB25DET gearbox $1400 ono
R33 GTR std 444cc injectors $250 firm
R32 GTR headlights $300 ono
R32 GSTt rear calipers $180
AU Falcon electric thermo fans $80
Momo Kevlar Race Seats with head wings. Price: $700 firm for both seats
I have no idea. I bought the engine for the non VCT R32 RB25DE head, the bottom end was a bonus. But it has just been sitting around doing nothing. I will strip it in the next few weeks and get some shots and work out exactly what is inside it
Lazy bump.
Cooler pipes are sold. I think the 6 pot Alcons are sold at a heavily discounted price. I have had a busy last few weeks so think I have caught up with PMs and questions
So Brembo F40s are sold.
Also found some more bits as I was digging through stuff in storage.
Exedy Hyper Multi Twin Plate Clutch. Less than 1,000kms on it and was removed due to change in gearbox type and therefore type of clutch. Suitable for an R32 GTR or R32/33 GTSt.
Asking $1,120, (Retail for ~$2,500)
Following is the Exedy chart for the clutch
Other random bits.
R34 GTR rear spoiler mounts - $50
Carbon Fibre R32 rear exhaust spat - Never used but has a small defect whilst being in storage (see 2nd pic) Asking $85
Also found today a Cusco air guide and offset licence plate mount. Plate mount is new in pacaging, guide scratches and tabs bent to mount with my JUN grille. Both are for an R32 GTR
Air Guide - $55
Licence Plate Mount - $85
CF Exhaust shroud now sold.
Update of parts still available:
Gizzmo Launch Interface (IGN Cut), Gizzmo Dual stage Shift Light, Adapter Loom for RB25 $280ono
Alcon Mono6 calipers $2200 ono
Genuine Trust T67-25G $1800 ono
Genuine Trust TD06H-25G turbo $1650 ono
RB20 gearbox and Xtreme Puck Clutch - $500 Box has 210,000kms on it and clutch has 50,000kms. Box has done plenty of work but still shifts as good as any high km 20 box and recommend drivign my car before purchasing as it is still in the car. Either the box is a freak box to have lasted as it is or I am easy on gearboxes
Now also for sale my TD05H-18G with 3" inlet. Its a Kando, new and never used. This stuff is being sold as work plans OS means pet projects are all being scrapped.
It has a Subaru core so is 360deg bearing with water cooled core and oil lube
TD05H-18G
med_gallery_462_50_247453.jpg?t=36239728
Asking $540 for the turbo with no exhaust housing or $750 with the Trust 8cm rear housing (3 bolt)
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
