As some of you may be aware i slipped and broke my GT-R yesterday.
I need helping with ideas of what has happened. the Symptoms are:
High pitch noise and white smoke from under the bonnet when trying to start.
It did start 1 time but i had a huge amount of white smoke out of the exhaust.
When we took our foot of the gas the car immediately cut out again.
Im thinking ive cracked a hose somewhere and the started motor may have pooped itself.
Thoughts?
IF anyone is keen there is a 6 pack for the person who knows what the problem is. as i'm pretty stumped at the moment.
I will be doing compression tests and all the random stuff on Saturday but i would just like some ideas on what it might be so i know where to go.
Thanks guys
https://www.sau.com.au/forums/topic/400440-pick-your-brain-gt-r-problem/
yeah the smoke is white, very white. but i have not seen the smoke since yesterday when it first broke. the car won't even attempt to start now. its got that high pitch noise and a bit of smoke under the bonnet when it tries to start. hence im thinking starter motor. but im unsure
I think started motor but im not sure. im still new to the skyline engines. but yeah it sounds rooted. but im unsure as to what else is wrong. because the whole car just died on me on the way home. i thought i might have run out of petrol but after all this it can't be petrol. so im lost. hopefully me and a few mates can figure out whats wrong tomorrow. p.s Anyone Thats free today that lives like condor area free that might have an idea?
thanks guys.
what exactly happened when it broke? Ie were you driving and it all of a sudden let go? with a big cloud of white smoke coming out the back? Was the turbo boosting at all after it happened? or did you shutdown the car straight away.
I was at idle going around a corner and the whole car just gave up, rolled to a stop. i had boosted about 3 minutes before hand. no smoke when it did die. I think what has happened is i was low on fuel and there was some gunk in the bottom of the tank and ive clogged my fuel filter somehow. and my started motor just chose this time to die as well.
Check the normals such as coolant color and see if it's got oil in it. Vise versa with the oil check if it's got coolant.
Maybe post up in the forced induction or general maintenance thread they will have a good idea as well.
Check for fuel so maybe pull the line off the regulator and prime it to see if fuel comes out.
Also pull the spark plugs out and make sure it's getting spark.
Im getting no response at all anymore, when it was turning over i got white smoke out the back off the car as well as a bit under the bonnet. tomorrow im pulling the fuel filter out as well as the starter motor. from what i can see i may have lost a tiny bit of oil, coolant is fine however. I was thinking head gasket to begin with but now im not sure. as when the car died i was low on fuel its very suspicious...
when i say no response my car the started motor sequels in pain however it does try to turn over, i know it isnt spark plugs/coils so im thinking its fuel related or a head gasket. i think the starter motor just decided to brake at this time and it isnt related (i hope).
What did the smoke under the bonnet smell like?
Have you ever smelled fuel thats not burning but its so hot it turns to white smoke? a very odd smell.
Do you know what fried wires smell like? (starter motor)
The other white smoke is coolant burning, after all the water has boiled away. smells like a chemical factory. like its gunna choke you.
Your nose is a chemical sensor that is very easy to use.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
