The time has come........I must part with my baby.
1993 R33 GTS-T Manual. Burgundy.
Car is all original and in immaculate cond.
Few extras are:
Blitz Automatic Turbo Timer with Digital Boost Display
Remote Start Alarm
Pod Filter
Brand new Australian Kenwood 4X50W Cd Stereo System
Rego till August
97,000 Kms
Just Serviced
Garaged
Only run on Shell Optimax or BP Ultimate Fuel (98 RON)
The car has been fully serviced including the timing belt, and has been extremely reliable.
MUST SELL due to having just finished my commercial pilot's licence. With mounting debt, and a forth coming journey in to the outback looking for flying work, she has to go. (No way i'm gonna take my baby out there to face the bulldust, i'd rather see her go to a good home)
First to see, WILL BUY
Asking $16,900 ono (for quick sale, Would have advertised it for 18K)
The car is currently in country NSW just west of Sydney. Can view in Sydney.
Can contact me via email [email protected]
or by phone on 0431 558 293
https://www.sau.com.au/forums/topic/40065-fs-1993-r33-gts-t-manual-unmodified/
Thanks.
Sorry about that...... I am currently on the Gold Coast where i have just finished my Pilot training. Will be returning to country NSW just west of Sydney shortly.
So anyone, on the Gold Coast or Brisbane could see it now, or Sydney guys (or people in between could see it in the next couple of weeks if i haven't sold it.
Rob
No point..... Just that i'm selling my car for 17k not for 8k.
I didn't import and comply it, i bought it privately already in Aus, and i can tell you it cost alot more than 8k.
Sounds like you want retail price for your car and trade price on a Skyline...... Good luck !!!
The car is now back in the sydney area.
For any of you guys that is after a skyline that hasn't been flogged or boosted, whether your going to keep it standard, or do it up, this is the car for you !!
At least you know you have a good base to work off, not something that is just about to pack it in because it has bad mods for too long.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
