wish i had done that with my 33 turbo.
ordered a Hypergear from melbourne, got boned on the installation costs and now I have a giant laggy as F@$# turbo that cost me a fortune and isnt that much faster around the track than NA Micras etc
research, research, research.
you cant do too much!
Really? Laggy?
My high flow was laggy and underpowered IMO.... Its why i went all out to the combo i have now (Well will have in a week or so when its finished)....
PAT! yours is also a t4 flanged turbo, not a t3, its some sort of other hypergear turbo, def does not have anything original on it :D
your boost kicks in at 5k rpm anyways. but from there on, it pulls like a train.
BTW, to OP, to upgrade your turbo, you might want to invest in a clutch as well.
Edited by Bronx
hamiltonau: Type B rear housing for G3 is released, you can send it back for free upgrade. Also you the tune in it was bad and pinning loud. I hope you didn't track it like that. Come pass when you are in Melbourne next.
Ya I have done done the following modes HKS electronic turbo booster, HKS intercooler, BC RC coils, Pod filter, Fuel Injector 550, .7 spark plugs, AFM, Apexi ECU, 3" inch HKS exhaust ..... should I stick with 550 or move to 650cc … anyway can u pls post ur mods
They are not bolt on. GTR/GTS-t = incompatible due to flange differences
Yeah, you're right.
Considering he wanted an aftermarket turbo / kit, I would have assumed things will have to change.
So yes, he'd have to modify the exhaust manifold / flange.
back to questions
what is your recommendation Skyline(OO) to achieve 550HP?
Lol, build your engine!
Why you being lazy? GO to the RB25 Dyno thread.
Look what I found....
R33 GTS-T Series 2
GT3076 IW .82
256 Cams
Supporting mods etc...
Caltex E-flex E85
Nismo 740cc injectors
Bosch 040 fuel pump
Still using the standard airbox (ported) and snorkel
349rwkw on 19psi spikes to 21psi
RB25DET S1
CP forged piston kit
ACL bearings
Cometic Gaskets
HKS 264 cams
HKS GT3037S-56T
HKS ext. Wastegate 50mm
Splitfire coilpacks
Nismo 740 injectors
Greddy Profec B
Z32 AFM
APEXi Power FC
Blitz NÜR Spec exhaust
Unfortunatelly we reached the MAHA LPS 3000 dyno limits, and it tilt down at 5700rpm.... sad.gif
1.6 bar
471 HP @ 5700
579 Nm @ 5200
As It seen on graphs those HP numbers are not the peak numbers, We estaminated 500+HPR33_GT3037_23PSI_.jpg
back to questions
A lot of work :laugh:
Read Hadouken's post as it's pretty much spot on.
But for starters, the turbo kit you GF bought for you off eBay, as it states, it is a GT3582R.
Garrett claims that turbo can produce a power range between 400 to 600 HP.
So you'd use that turbo and then you need the supporting mods to handle the power.
I see that you have done Injectors / ECU / AFM / Exhaust / Air Intake / Intercooler / Spark Plugs / Suspension, now you need the rest to go with it... Re-read Hadouken's post.
Now can your Gearbox / Clutch / Brakes / Tyres handle the power? They will need upgrading.
Is 550HP streetable? :)
Hey guys .. I dnt know if I should open a new topic... I was away for few days just got back to melbourne...
I had a word with workshop ppl ... He also recommended the same turbos as you guys.. but he also said no to manual transmission.. as my car is Semi Auto .. I think its Multitronic ... he said around 10% power is been reduced coz of transmission
do you guys recommend it or should I just stay with the turbo upgrade. ? ATM my car is pretty sweet ... i mean transmission wise and engine wise .. i do service every 3000 and keep it clean drive carefully ..
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
