  • Replies 142
Bring whatever, should be a good cruise either way.
This.
Doesn't matter what you're driving, just come, socialize, and have some good food, getting to know your fellow forum members.
With the plates HOONS I'd be GTFO your way too lol.
80% coming to this, wasn't planning on going as my car may be sold soon and didn't want to rack up any more KM's but fuarkkk it :P
I'm out.
Faulty valves on my repaired wheels keep leaking air. Can't get them replaced until Monday :angry:
Why not?
Where you located?
What valves?
Might be able to help....
Bring spare 12v pump :P
Got a pump, that's not a problem ;)
Sadly one in particular loses air very quickly when driving, so ah no, not going to risk almost brand new tyres and wheels hoping it's not going to go flat on the journey :(
Ok people from Sydney.
To coincide with the albion park meet up at 11.30.
Meet at KFC cross roads(prestons or casula) at 9.
10 sharp leave time.
We then have 1.5 hrs to make it to the meet point.
Rough estimate on Google maps, it should take approx 1.25hrs, so we can take it easy, and obey all the rules.
See you all there.
hey which exit off the M5 is this crossroads thing? gps is farked so i will be winging it a little.
Take the Camden Valley Way off ramp........
See you there.
I'm really looking forward to this run......
Bob.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
