not long ago i had an issue with my car leaning out which ended up being that my bosh 040 intank pump was full of shit.
it semed that somehow a lot of crap had gotten into the tank and had clogged up the pump.
anyway i replaced it with a brand new one.
this made the missfire dissapere and you could no longer hear the pump which was no longer straining.
recently i have been getting another misfire (felt a bit different but...)
took the car to boost worx and they poped it on the dyno to check out what was going on.
it is leaning out again at about 5000rpm. the pump is noisy again.
i can only assume the tank is holding more shit.
i can get it cleaned out but if its rusting or contaminated then it wont fix it properly.
what is the best thing to do get the tank somehow cleaner more thoroughly? get a 2nd hand one and hope it in good condition. i assume u cant get new ones anymore?
(r32 gtst)
https://www.sau.com.au/forums/topic/401304-fuel-tank-full-of-crap/
Does your fuel filter (on replacement) reveal the so called crap?
If not, your tuner can check if there's current fluctuation to the pump > leaning out.
If that's so, a hard wire job may be required.
If the current is steady, it can be the pump itself as happened to my 044. My tuner at Unigroup showed me and another technician how the pump itself was displaying a deficient flow rate.
The parts company asked for the pump along with someone else's faulty 044 to be brought in so that Bosch could test them.
I marked the pump and handed it in, in the Bosch box.
Bosch took over a month with the pump and only at the behest of myself was 'it' returned.
'It' was in the box I had, but it came back without my mark. Bosch said there was nothing wrong with my 044 and said that they would not replace it.
How come they did replace it with 'it', and then deny fault? Is reputation worth telling me an untruth?
I hope you get to the bottom of this without too much fuss. Sorry to digress.
Lol replace it but save face maby.
All I know is that on the dyno first run it was ok the the other %90 of runs it leaned out again.
They re grounded the pump and found te wiring to be fine but I didn't ask any further.
The fuel filter I'm not sure I didn't ask again but the last time I replaced y pump 5000km ago the mesh sa clogged badly by crap.
We assumed that when the last owner put it in allot of shit from the dirty stripped out boot fell in and we just ran the tank too low.
The pump is noisy again which makes me sound like its straining again and has dragged more shit up.
Also they d tell me to swap to a ..... f**k can't remember te brand of pump. Cheaper and has serviceable mesh cover.... Densel or denso rings a bell.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
