hey guys did a quick search but couldnt find really anything about n/a. question is does a gts-t clutch fit an n/a. found one thread where someone said gts25's came with rb20 gearboxs instead of a 25 box.
also were there any high spec gts's that came with turbo componets, such as 5 stud, red badges? my car has these but im pretty sure the previous owner didnt do these mods unless it came from japan that way.
and finally what clutch would you recommend me. car will be used majority for the street but i am planning on taking it to the track and drifting, doing a few clutch kicks to help me get round. was thinking something like an excedy heavy duty clutch. dont want anything too expensive. http://www.ebay.com.au/itm/320887451155?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
thanks for any feedback you give
https://www.sau.com.au/forums/topic/401665-na-clutch/
as far as an upgraded gts goes they made a type s, which had an LSD diff, rear swaybar, slightly different exhaust and red badges.
also the na boxes are a lot weaker then turbo boxes. (a quick look will tell u that, they're physicaly 2/3 of the size)
plenty of clutch threads around, search harder :)
https://www.sau.com.au/forums/topic/401665-na-clutch/#findComment-6383353
A GTST clutch will only fit if you put a GTST flywheel on. Just get a heavy duty clutch to suit the 6 bolt NA flywheel.
thanks for the info, wouldve just bought and assumed a gts-t clutch would fit otherwise
thanks think mine might be a type s or optioned up version then seeings as i have red bagdes, rear sway bar and some sort of lsd.
what do people think of hcb clutchs. sold in melbourne so they cant be too bad although they are cheap considering autobarn quoted me around 440 for an oem one. looking at this http://www.ebay.com.au/itm/NISSAN-SKYLINE-CLUTCH-KIT-GTR-GTS-R31-R32-R33-/360159712014?pt=AU_Car_Parts_Accessories&hash=item53db31130e
https://www.sau.com.au/forums/topic/401665-na-clutch/#findComment-6383497
It will fit no problems at all non genuine usually only list a GTS-t but in most cases it will also fit a GTS. Ive done it twice now.
There is no difference in flywheels in GTS and GTS-t's, they are the exact same the part ...... the part number is 12310-AA101
Also buying a heavy duty clutch wont have much benifit for kicking the clutch as the clutch disk is the same part in all clutch brands for there basic kits and the heavy duty kits. Heavy duty just means a upgraded pressure plate. The only time the disc is different if you change to a button type clutch.
https://www.sau.com.au/forums/topic/401665-na-clutch/#findComment-6389464
Sorry thought the rb25de flywheel is also 225mm. Wouldn't the HD clutch bite better when it's dumped?
Not a great deal, only to some degree. Its just a increased clamping force to reduce the disc sliping in non stock cars.
A button clutch is perfect for dumping the clutch.
https://www.sau.com.au/forums/topic/401665-na-clutch/#findComment-6394863
  • 1 month later...
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
