hi im making a list of stuff for my RB25/30 build
Spool RB30DET (DOHC) Rebuild Kit CP 9:1 $2,015.00 RB head oil drain kit $285.00 HKS cams 252/264 $800.00 RB30 $240.00 RB25det head $300.00 RB20 covers oil pump spool $790.00 oil restrictors $30.00 crank collar $175.00 timing belt (from mate) $50.00 turbo manifold 6booost (from a mate) $500.00 injectors intake (from mate) $400.00 HTA GT3586R turbo $1,800.00 water pump N1 $180.00 RB25det gearbox R34 $1,600.00 ECU $1,300.00
tolal estament atm
$10,465.00
need help with picking coils and have i forgoten anything
CHEERS Oscar
Edited by MRHD66
https://www.sau.com.au/forums/topic/401739-rb30det-parts-and-help/
I found some brand new stock oem coils on ebay which seem to be fine otherwise Splitfires. What is your power goal and do you plan to track it? Stock rods are probably ok up to 350kw but get new rod bolts and of course main and big end bearings. Do you have a wastegate and bov? I would forget the head oil drain kit but drill and tap the sump for breather(s) - have a read of the oil control thread http://www.skylinesa..._sk+oil+control
If you are going to track it get a bigger, baffled sump. If not at least get the Tomei baffle kit. You'll need a line and some fittings for the vct and probably some lines for the turbo and probably all new belts and hoses - don't get the N1 water pump as you will not be doing 8000rev/min. Oops - just saw your water pump thread - if you plan on running your RB30 at 8000 rev/min you will need a new quality harmonic balancer probably some valve springs possibly a modified ignition trigger depending on ecu as well as getting everything balanced. I run mine at 6500rev/min max (limiter set at 7000).
350 to 400 !! And yes it's goin to get balenced and new balencer what you recommend ? And will get head o ringed and ported too will be used to drag and on street it's goin into a HD Holden so have to modify the sump anyway will make it as big as we can was also thinking RB25 oil cooler set up on it too
Edited by MRHD66
Wouldn't bother going to the trouble of O-ringing it's pointless. Just get a metal head gasket and arp studs, though if you're only looking for around 350kw you can get away with a stock head gasket and arp studs if you have a good tune.
As for porting just clean up the protrusions in the exhaust ports and give them a polish, no need to mess around with intake.
A balancer you'd want would either be a Ross Tuffbond or ATI.
A sump that can hold 6.5L with good baffling should be enough and with your oil drains drilled out and cleaned up you won't have a problem.
what Ive told some other good ppl i know, including ppl on this forum who have built there beasts.
take your number, and double it. then take 25%. then your in the ballpark of what it will all cost. provided you do alot of the work yourself.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
