So iv been checking this forum out for a while now,theres so much good technical info and good reads i thought i might aswell start my own build thread.
Iv got a few builds on the go but my main focus is my R32 which is 99% complete and we have just started tuning.
here we go
Quick spec list:
RB26dett (120,000kms)
Stock internals
T04-r Turbo
Trust copy manifold (braced)
Tial 44mm v-band wastegate
3" stainless exhuast finishing next to gearbox
HKS intercooler kit
Greddy oil cooler kit
Greddy magnetic sump plug
Nissmo oil filter
Koyo copper radiator with viscous and shroud
HKS air filter
HKS earth kit
Yellow jacket coil packs
modified factory sump
N1 water pump
surge tank setup with walbro and bosch 044
Link G4 ECU
D2 coilovers
JIC magic front camber arms
JIC magic rear camber arms
some random castor arms
solid subframe bushes
strengthend castor arms mounts
cusco strut brace
cusco rear swaybar
RB20det gearbox
extreme drift 6puk clutch
17x9.5 drift teks/17x9.5 Rota grids
25mm spacers
Racepro drivers seat
Silvester camlock harness
Greeedy,Omori,HKS guages
Blitz dual sbc boost controller
Apexi RSM
Full 8 point roll cage
Drag wing
And the mission began by transfering everything from my non-compliable GTR into my caged 4 door
Imported this from garage defend
Engine out
Then i started adding all the adjustible suspension arms etc
https://www.sau.com.au/forums/topic/401887-4-door-fever-~-rb26-r32/
  • Replies 91
Cheers guys, Yea trying to keep the looks pretty simple dude,and it can always go lower!
This is the stage im at now, iv had her running a couple times and everything seems to be good,ran really good from the get go as we could just adjust the master fuel to get it to idle fairly lean as im still runing all the rubbish under the plenum, we also added the TPS map from my friends rb26 to speed things along so hopefully ill have it on the dyno soon.
There wasn't much room for the wastegate & screamer
And a quick video
Love it looks great, but a bit funny with the flared out front and standard rear. you can get some wide body kit for the rear of these. someone on here is in the process of doing it
http://www.skylinesaustralia.com/forums/topic/398169-mohsens-wide-body-r32-sedan-buildsemi-restoration/
Haha yea i had to add that filter/air intake,it would of just sucked up so much hot air! and yup its rwd mate
Yea iv seen the wide body rear guards for these but im just not much of a fan of widebody to be honest,the GTR front guards will be as extreme as ill go i think ;)
Thanks for the positive feedback :thumbsup:
My other project on the go at the moment is the laurel,this will be sort of a daily driver :happy:
Drove it around for about a year rb20e manual so now im in the middle of swaping in an rb20det.
Replacing all the factory arms with adjustible ones,i also have a nolathane rear subframe bush kit and an r200 lsd
Fresh import motor 110,000kms, in excellent condition
Also my old man owns this, 100,000kms Turbo manual Nissmo model
yeah its just opinion really, i don't think may people would notice anyway.
what are the offsets on those rota grids? didn't think they looked that good on a 32, but now iv seen them i kinda wan't
Their just copys of Te37's bro they look good on alomst everything! haha
Sadly I only have 2 of them,but mine are 17x9.5 15p,iv got 25mm spacers on the front to but with the GTR guards and massive camber they sit in guards.
You can also get them in 18x10,but im not sure of the offset
Edited by NZDRIFTER
So over the last couple of weeks my mate/tuner mike and i have been doing the final touches to the car before we start tuneing.
Its not pretty,but weve wired in a direct power feed from the batter for the coils & igniter,the loom beeing that old that there definantly would have been a voltage drop to the coils,as we have found on alott of cars this age lately,so combined with the new yellow jacket coils we shud have a nice strong spark.
Started wireing in my Apexi RSM and wireing the the Inovate afr guage into the link ecu,
also intalling a distribution block,plus i added a 10" electric fan on the back
of my intercooler since their was so much room down there, should help with inlet temps when the cooler isnt get much frontal airflow
my assistant
Edited by NZDRIFTER
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
