So iv been checking this forum out for a while now,theres so much good technical info and good reads i thought i might aswell start my own build thread.
Iv got a few builds on the go but my main focus is my R32 which is 99% complete and we have just started tuning.
here we go
Quick spec list:
RB26dett (120,000kms)
Stock internals
T04-r Turbo
Trust copy manifold (braced)
Tial 44mm v-band wastegate
3" stainless exhuast finishing next to gearbox
HKS intercooler kit
Greddy oil cooler kit
Greddy magnetic sump plug
Nissmo oil filter
Koyo copper radiator with viscous and shroud
HKS air filter
HKS earth kit
Yellow jacket coil packs
modified factory sump
N1 water pump
surge tank setup with walbro and bosch 044
Link G4 ECU
D2 coilovers
JIC magic front camber arms
JIC magic rear camber arms
some random castor arms
solid subframe bushes
strengthend castor arms mounts
cusco strut brace
cusco rear swaybar
RB20det gearbox
extreme drift 6puk clutch
17x9.5 drift teks/17x9.5 Rota grids
25mm spacers
Racepro drivers seat
Silvester camlock harness
Greeedy,Omori,HKS guages
Blitz dual sbc boost controller
Apexi RSM
Full 8 point roll cage
Drag wing
And the mission began by transfering everything from my non-compliable GTR into my caged 4 door
Imported this from garage defend
Engine out
Then i started adding all the adjustible suspension arms etc
https://www.sau.com.au/forums/topic/401887-4-door-fever-~-rb26-r32/
  • Replies 91
Cheers guys, Yea trying to keep the looks pretty simple dude,and it can always go lower!
This is the stage im at now, iv had her running a couple times and everything seems to be good,ran really good from the get go as we could just adjust the master fuel to get it to idle fairly lean as im still runing all the rubbish under the plenum, we also added the TPS map from my friends rb26 to speed things along so hopefully ill have it on the dyno soon.
There wasn't much room for the wastegate & screamer
And a quick video
Love it looks great, but a bit funny with the flared out front and standard rear. you can get some wide body kit for the rear of these. someone on here is in the process of doing it
http://www.skylinesaustralia.com/forums/topic/398169-mohsens-wide-body-r32-sedan-buildsemi-restoration/
Haha yea i had to add that filter/air intake,it would of just sucked up so much hot air! and yup its rwd mate
Yea iv seen the wide body rear guards for these but im just not much of a fan of widebody to be honest,the GTR front guards will be as extreme as ill go i think ;)
Thanks for the positive feedback :thumbsup:
My other project on the go at the moment is the laurel,this will be sort of a daily driver :happy:
Drove it around for about a year rb20e manual so now im in the middle of swaping in an rb20det.
Replacing all the factory arms with adjustible ones,i also have a nolathane rear subframe bush kit and an r200 lsd
Fresh import motor 110,000kms, in excellent condition
Also my old man owns this, 100,000kms Turbo manual Nissmo model
yeah its just opinion really, i don't think may people would notice anyway.
what are the offsets on those rota grids? didn't think they looked that good on a 32, but now iv seen them i kinda wan't
Their just copys of Te37's bro they look good on alomst everything! haha
Sadly I only have 2 of them,but mine are 17x9.5 15p,iv got 25mm spacers on the front to but with the GTR guards and massive camber they sit in guards.
You can also get them in 18x10,but im not sure of the offset
Edited by NZDRIFTER
So over the last couple of weeks my mate/tuner mike and i have been doing the final touches to the car before we start tuneing.
Its not pretty,but weve wired in a direct power feed from the batter for the coils & igniter,the loom beeing that old that there definantly would have been a voltage drop to the coils,as we have found on alott of cars this age lately,so combined with the new yellow jacket coils we shud have a nice strong spark.
Started wireing in my Apexi RSM and wireing the the Inovate afr guage into the link ecu,
also intalling a distribution block,plus i added a 10" electric fan on the back
of my intercooler since their was so much room down there, should help with inlet temps when the cooler isnt get much frontal airflow
my assistant
Edited by NZDRIFTER
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
