  • Replies 91
Now that the exhuast is all finished i think ill had a few more mount's to it, aswel as heatwrap the dump pipe and the rear section of the exhuast around the fuel tank.
Im thinking about painitng my intake manifold with some black wrinkle paint
Having just 2 vband clmaps for the exhuast makes removal so easy
Edited by NZDRIFTER
I'v also bought & fitted the extra accessory loom from link, making it so simple to wire in a switch for duel maps, electric fans etc all controlled via the link.
Loving this exhuast, just wana see the car on the ground :)
And for the laurel i have an HKS oil cooler kit to go with the HKS intercooler kit.
The old mans in the middle of susing a Nistune for the 34
Also my mate phills super clean R32
The subframe is almost ready to go back into the laurel, im just waiting on a few parts, then ill start putting in the new engine.
This should do for the final exhuast mount
It's all a very snug fit
Im thinking about just leaving my plenum as the sand blasted look for now, paint will just get ruined when re-fitting.
Cut my wheel studs down so now i can run a 20mm spacer with my drift teks
  • 3 weeks later...
I finally sussed some decent gaskets for the 26's throttlebody's
And some camber arms for the laurel so i was able to complete the subframe and fit it back under the car and start removing the single banger ;)
  • 2 months later...
So i finally got the engine back together a few weeks ago.
You can never have to many RBs ;)
And finally got her back on the ground
Xmas present from the misus
Iv been talking to my tuner and i should be able to take it out to him in the next couple weeks, so iv fitted some 18s to help it clear everything on the dyno
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
