Nice job, must have taken a lot of work but when I buy my RS-Four I think I'll retain the original style.
Also couldn't help noticing the corrosion on the pictures with the wings removed, are Stagea's prone to corroding or do they just rust a little due to age?
Edited by FireFox-89
Its a Stagea and skyline thing. Im getting the corrosion cut out and new metal welded in soon. The suspension towers are a twin skin and its common for water to get in and sit between the two skins causing the corrosion.
  • Like 1
Installed a Walbro 255 fuel pump on the hearse today. Didn't take to long, About an hour.
Bit of an odd set up compared to Skylines and S15's. The pump is house separate to the sender in a white box in the fuel tank.
5443C054-204A-4E3B-942A-2EF7A4B408CD_zps
Do the wings bolt off or do they need cutting off?
  • 1 month later...
  • 2 months later...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
