Eoi:- Private Drag Day At Adelaide 1/4 Mile. July 1St 2012
Matty, chin up mate, there'll be other private drag days - I'm keen to do a few.
Jet, sounds good.
I might pass the word around my work, should find one or two, or more, keen to get involved.
  • Replies 197
Posted Images
My mate that was Trying to get the original day going would be keen aswell as a couple of others.
I may be ready on july 1, but later date would be better.
The week after a scheduled meeting would be best for the track condition as it would still be sticky, im pretty sure there is no track prep for a private day included in the cost.
I'll check on track prep and confirm ASAP.
The next scheduled meet is 29 July.
On Edge, sounds good mate.
Matt
Can you also ask how fast times we can run without a cage etc.
At normal andra meet 11.0 us the fastest you can go before they kick you out, im hoping this is different on private day.
Andrew
Matt
Andrew
anything faster than 10.99 need a cage anything faster than 9.99 parachooooote as per andra specs
Okay, I've had a chat with the venue manager, Rino - good bloke, more than happy to take time and explain everything.
Basically, there are three options:
1. $3500. Max of 10 people/cars. No timing system. No track prep. $350 per person.
2. $5500. Max of 20. Full timing. No track prep. $275 per person.
3. $7500. Max of 20. Full timing. Full track prep. $375 per person.
All options include: Full safety crew, ambo and fire etc. 9am till 4pm time frame.1 driver + 2 pit crew. No additional spectators (other than pit crew). Wet weather refund or reschedule for alternatively date.
Numbers are set based on insurance requirements. One or two above 20 is possible but he would prefer to avoid it as it creates significant issues regarding insurance and adds additional fees per person.
No ET or MPH limits (within reason - no 7sec @ 180mph stuff) so below 9.99 is fine.
I guess the next move is working out if people are prepared to pay $375 for track preparation. I've driven my R33 at AIR minus track prep and it was interesting to say the least! Wheel spin 1st through 4th with a mere 260-270RWkW.
Worth noting on the quarter mile day a few weeks ago I had 11 runs with plenty of breaks during the day. I could have had 15 or so if I wanted.
Cost was $160 with full prep and timing etc
I'd highly recommend it
That's a more sensible price, 375 is really pushing it in my opinion, significantly more than a private track day for circuit !!!
Fair call, Josh, it's hard to ignore the value for money in a regular open off-street meeting. I'll be at the July meet regardless of what happens with this private drag day.
Matt, as i mentioned earlier if you get private day week after the meet the prep us still good.
I wonder how much a drum of vht costs, couldnt be much surely?
Only gets sprayed on with a garden sprayer, anyone could do that
seriously go the weekend after a event, decent tyres are a minimum anyway octopus grip is cheap and works better than vht cause u add it to ya tyres( paint brush) and even when u go heathcote theres no track prep its just the first coupla v8's lay some fresh rubber and away u go, ( track prep is overated if not done right anyway ) and 375 is getting up there whereas 275 is ok for what were getting . as long as theres timing and a slip ur going to p.b anyway as ull have heaps of runs to get it right and as the day goes on and temp rises the track turns for the better and runs faster just before 4ish ( baised as the winter we currently have) just sayin dont get hung up on track prep thats what the extra 5 seconds of spin is for :P
If i can get some proper tyres ill be out there again.
any recommendations for a 33 gtst rim and tyre size?
as wide and as high as u can fit m/t's do a bunch of irregular sizes to suit
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
