Hi Every1,
Was wondering if anybody has the part numbers for what would be known as a 'double din conversion kit' for a R34 GTR?
Interested in how many parts are included in the kit.
I have factory NAV in my GTR, hence why I need it. Wondering whether the air con replacement is a new facia which snaps on to the existing air con control unit, or whether you need to replace the whole thing?
Thanks in advance.
Edited by iwanta34gtr
Its already double din iso ( tiny bit off double din todays standard but not much to worry about )
No kit needed but some trim rings wont fit right without filing the trim ring slightly or some dont need trim ring mounted , only slot the existing holes in the cage holding the radio to set it back a bit further to make it look perfect
Note tape a thick soft towel around the console / gear surround to set the razor sharp cage on or it farks the surround black bits and its near impossible to repair ,
Double din rules fark the single din look is boring
Hello, thanks for your reply.
My car has the NAV unit, I need to convert it to the one like in the pic in the previous post.
Air con controls are one step further down and the NAV unit controls are in its standard place. The air con unit is a little bit smaller than standard.
Its been covered a few hundred times
But you just need the face plate off a newer or gtt , gt model car for the a/c and move it up a spot
The double din cage exists already behind the pocket
The controls fit exactly the same just fills the gap all the way across
The nav wont work here anyhow , the mfd will and can be used still , where are you located
Chris rogers on sau deals a lot with these parts and will help you a fair bit
Mine has ambient air , the newer cars came with it , mine has snow package as well , heated mirrors , sunroof heater and a super demist function in the control for a/c
i have a few facia's in the shed i'll see if i can find the part # in am
The parts dont have embossed numbers and no stickers?
Pm your email addy and i can send photos to you of what I'm
Talking about ( crappy iphone not able to use flash to upload !!)
And photofark it times out
you only need the plastic face not the guts , it just unsnaps
And you swap them over , screw to cage and back into car screws under mfd
And vents out
Edited by Carbon 34
Yes mate, spot on.
Yea fair enough, mine came with the aircon unit up top so cant help you much there.. i just removed the old single din unit and replaced it with a nice alpine unit.... goes really will with the interior i think.. not cheap though.
you palnning on putting in something like that?
Sorry thats not right
You only need the facia not the whole A/C climate control , gtr and some of the other R34 have ambient air temp sensor as well so you have to be careful which one , the silver knob pushes in on ambient air temp model the other one wont
The sensor is just in front of the lower driver side radiator , a plug with a small item in held out space and held on with 10 mm bolt
You just unsnap the old single din shaped faceplate, unbolt the circle behind the knob first
And slap on the new wider angled one its that easy and bolt on the circle bit and shove the knob back on , its a good time to go change the lights to LED since a lot are burned out and dated looking anyhow
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
