parts not available: bonnet
left gaurd
windscreen
left door ( possibly just hinges but will check out tomorrow)
possibly some suspension parts on left hand side
wheels
most other parts are available.
for now , contact via pm or post here
https://www.sau.com.au/forums/topic/402216-nsw-wrecking-1996-s2-r33-gtst/
  • Replies 66
it took a hit to the front left bud so suspension and surrounding bits wont be anygood from the front left of the car, had a quick look , shock , caster rod , and lca are all bent.
not sure what prices to put on some of the parts so throw me offers too.
FMIC with piping - $250 ono
near new oil catch can - $60
standard pink label ( s2 rb25det ) AFM - $100 ono
s2 seats - perfect condition - $ 300 front and rear ono
s2 steering wheel with air bag - $ 150
s2 dash perfect condition - $450
drivers door - white (shit paint) no dents or scratches - $150
drivers front guard - good condition , no dents - $50
all interior plastics ( centre console , dash face plastics etc) - all good - $200 lot
nothing in the engine bay was damaged luckily so anything needed from there hit me up.
motor and gearbox for sale also with 66xxx kms , runs excellent!
more parts to come , my number is 0431 121 625 text for any questions or parts you need
Edited by d_soljah
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
