Hey everyone,
I am after some Tie Rod Ends for my R33 GTR.
The genuine nissan ones are around $100 each, are there cheaper after market alternative's available?
Also is it best practice to just replace the worn out one, or replace both left and right?
Called them up, said they are marked for the R33 GTs-T, and in the comments says "Will not fit R33 GTR"...dammit lol.
I might go and grab them anyway as i am in the area. If they fit, they fit. Otherwise can return.
$35 like you said.
Have you used those ones on a R33 GTR before xalmon?
Checked out the ones i got from Bursons.
No go, they are heaps smaller then the ones i have on there.
Didn't even bother to fully open them up as they won't fit.
Ill try pedders, otherwise I think i will just go genuine from Nissan for $100 each :(
Definatley looked on eBay, I do need the outer tie rod ends.
the ones being sold for the R33 GTR, are not compatible. More so of a scam/false advertising. Check out the pics in both the R33 "4WD" and RWD ones, pics are of the same item. They are the exact same ones i got from Bursons. Probably sweet for a R33 GTS-T, but the R33 GTR part is different. Its quite bigger physically. Its a bit fatter and the thread at the top is longer.
I have done a search on a forums for the ones sold on eBay, found a user stating they don't fit. He could have gotten his money back, but as usual you have to pay return shipping. Probably voiding any effort of a refund.
Ended up just ordered some in over the phone from my local nissan dealership.
$111 for one >_<
Not sure if ill do the other one at the moment, as it has no play....
Edited by Booki
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
