Still waiting man... I dont want to rush them, i know they have it under control... I am just so keen now that i know its close!!! The head never came off ;)
Maybe the Charlestown idea isnt that bad then, then maybe a quick cruise around Warners Bay or something?
There would be a few cars tagging along with me....... IF i ever have my car :P
This is the place - http://www.mattara.com.au/
ahh yea i know that one, yea that has a massive carpark behind it next to the cinemas etc.. would be a good spot i think, we wouldnt take up the whole place and cause any unwanted attention.. i think thats a goer mate, i like it..
anyone else have any objections or other ideas?
nice, sitting, beer in hand whilst oogling skylines... nice afternoon that...
Perfect :D i am keen to check out your CF parts!!
isn't that the place down the road from the police station?
Its tucked away, its right near the big shopping centre, the police station is over the back near maccas i think? Either way, we will not be attracting any unwanted attention so it should be fine :)
not sure where the police station is to be honest...
seems to be ticking all the boxes though... might need to start looking at dates / times etc.
what suits people?
The only delay for me is the car and not knowing when itll be ready, but you guys start making a time and even if i dont have it ill make an appearance anyway! BUT fingers crossed i have it!
All sounds goodto me, make it an event?
Not sure if we should make it an event until we get more feedback from others? i THINK the date is OK but am generally useless with double booking things so i will check, but i think once we all agree we can make it an event so that others can see and attend if they like :yes:
Yea thats sounds like a plan...
lets sit on it to see how things go then make it event next week or something.
Where you from man? We will make a plan that suits as many as possible, it's not gunna suit everyone as its not a perfect world, but hey, we have the ball rolling so let's keep it up ;)
AND if I'm gunna make a PAC cruise, your gunna make a Stockton meet! Deal? :P
im from the coast doyalson area but id come up on the weekend for lunch at the mattara if it goes ahead.ill come to a stoko meet if its a weekend
Also post up if your interested in a feed there for lunch? or just an arvo beer etc...
i reckon a feed sounds like the go, just a casual lunch and beer into the arvo then go for a quick drive somewhere?
Oh good stuff, well the Mattara meet is pretty easy for ya then... And stoko meets will happen on a semi regular basis once we are all sorted, i will organise with you guys once my car is back..... It will just be a casual SAU thing, no need for official meets etc
Yea sounds like a good plan... hopefully get a half decent turnout. newcastle is a fairly large place, would think there would be quite a few people on SAU keen to get amongst it??
There are plenty of cars up here but not sure how many SAUers..... All the guys i met up here were through HT.net or NS or whatever its called now, i havent logged in there for years......
It may take time before the SAU_Newy thing catches on but i think its an awesome idea and have been looking forward to it for ages now ;)
Just read the plan. Sounds awesome.
I'm off work that weekend, so i should be around
Good stuff, we will probably wait a while before posting as an actual event, but i think the plan should work pretty well! So far SAU Newy will be repping the 34's :D
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
