Martin, response is my next goal.... Bigger exhaust etc.... IF my engine retires I'll be keeping the NEO setup..... May stroke it tho..... Chick dig stroking..... Wait..... :P
And Chookie, Cusco is winning.... But shimming will do ya for now
off hell yeah they do :cheers: spesh after few of them <<<
ill have a cusco 34 soon enough, well maybe, they are pricey friggen parts
Where is difftrans? Is he good??
Martin my car is fine. My LSD has never worked and only just relised GTTs have LSDs at Texi wen mat picked up that I was single pegging. So I'd like to get it sorted so I can launch.
the factory lsd's are good for a bit then wear out, best bet is to shim it up if your after a cheaper fix.. then you can have it as tight or loose as you want sorta thing, hopefully ill get the twins to make mine twin :)
He is in that steel river industrial part, of you turn into that industrial area and turn right at the roundabout you'll see the sign on the roof in from of you....
Ask for Aaron, he is awesome at what he does!! Last time I was there he had Tinklers GT3 gearbox there so considering that gearbox is worth more than my car I trust him :P he has built my diff and a heap of mates and we are all very happy! Price was good too
Ah okay
Let me know how you get on.
I keep lifting a rear wheel getting in and out the driveway so not sure how long the diff will like it for
Ah okay
That's nothing to do with the diff tho, it's just a skyline/coilover thing.... It puts no real load on the diff that's gunna do damage, unless you drop the clutch lol....
And the diffs are really strong.... It's the LSD that seems to loosen up a bit (like Chookie) hahaha
My build is ages away from even starting. The parts I ordered from Japan have been at Sea for 4 weeks...and the standard time is around 6-9 weeks for delivery.
Also, arranged a CES Front/dump pipe pipe and hi-flow cat....but still have to organise a catback exhaust.
Should get a 38RWKW gain from upgrading the exhaust system.
I can get a 3 inch Reinhard Canonball Catback Exhaust for $350 (its been used)....but it doesnt have a resonator. I heard the reinhards without a resonator register something like 113DB at 5900rpm for Sr20's =|
talking bout build threads, i just bought some 225/40/18's to slap on my 18x9.5'' rims, my candy red Hicas lock bar is in transit, along with paying postage on my new cusco coilovers, and waiting on ryan to drop my 3"front pipe and highflow cat over.. might splurge on some camber arms tonight and hope i get enough to finish my tattoo next pay :D
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
