Quickly followed by you falling on your arse ha, was such a funny night! Thanks for having us...
Martin, have you put in the name change request? Hahaha
Not sure about the 21st? Not sure if we came to a conclusion? Old pac?
Yep, 2 Min Noooooooooooooooooooooooooodle :P
The conclusion seemed to be a crack of dawn Old Pac run then back through wisemans for lunch i think?
yea i was thinking 6, but.. that is very early on a sunday (would have to be up by 4, on the road before 5) hahaha... just one thought onit though, daylight savings will be on before then, will it be dark at 6am by then?... just a thought..
Yeah I think we agreed we gotta post a few more to get everyones contacts?
But that night is a blur so I could be wrong
Oh yeah, maybe your right lol
I dont remember and i was the only sober one :laugh:
hey guys just letting you know i have a set of wheels for sale off my R34
http://www.skylinesaustralia.com/forums/topic/409042-avanti-18x8-and-18x9-skyline-mags-2-of-each/
Also i am looking to tune my R34 it has apexi FC does anyone know or have used anyone in newie or the coast?
http://www.skylinesa...mags-2-of-each/
Pm DVS JEZ apparently he's good
Jarrad nailed it, Jez is the man to see!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
