Quickly followed by you falling on your arse ha, was such a funny night! Thanks for having us...
Martin, have you put in the name change request? Hahaha
Not sure about the 21st? Not sure if we came to a conclusion? Old pac?
Yep, 2 Min Noooooooooooooooooooooooooodle :P
The conclusion seemed to be a crack of dawn Old Pac run then back through wisemans for lunch i think?
yea i was thinking 6, but.. that is very early on a sunday (would have to be up by 4, on the road before 5) hahaha... just one thought onit though, daylight savings will be on before then, will it be dark at 6am by then?... just a thought..
Yeah I think we agreed we gotta post a few more to get everyones contacts?
But that night is a blur so I could be wrong
Oh yeah, maybe your right lol
I dont remember and i was the only sober one :laugh:
hey guys just letting you know i have a set of wheels for sale off my R34
http://www.skylinesaustralia.com/forums/topic/409042-avanti-18x8-and-18x9-skyline-mags-2-of-each/
Also i am looking to tune my R34 it has apexi FC does anyone know or have used anyone in newie or the coast?
http://www.skylinesa...mags-2-of-each/
Pm DVS JEZ apparently he's good
Jarrad nailed it, Jez is the man to see!
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
    • Hi guys,  I just replaced my pads with blue stuff and flushed fluid. The pedal and brakes feel fantastic but I'm getting very slight pedal stutter under any kind of braking. Not every time, maybe 1 in 10 and not under any heavy braking, mostly occurs as I'm reaching a stop. It feels like abs engaging but it's so fast, there and gone in under a second and no abs flash on the dash.  Any ideas what could be causing this?
    • How does dead head help with emissions? Is it being claimed for emissions because fuel in the tank isn't being heated up by being pumped around, hence should condense more? One part that is a negative about dead head is heating the fuel at the rail a lot more (IE heat soaking at traffic lights) and this causing lean outs on takeoff afterwards. If my thoughts above are correct, I wonder how different the tail pipe emissions become with the lean outs vs less fuel tank emissions into a charcoal canister
