Never driven on a track, never driven that track! I'm gunna die :P
Matt, few tips.
- Brake (when you're going in a straight line) just before the corner. This shifts weight to the front end and allows a sharper turn in. Can unsettle the car if you brake while turning.
- When you're going into the corner, look at the apex and look where you want to exit. You ideally want to take the corner in a straight line after you've turned in.
-Don't be afraid of coming out wide on the corner, this can help to minimise tyre squeel and allow you to start accelerating earlier, the secret is to use all the space the track gives you.
- Once you've hit the apex of the corner you can accelerate.
360rwkw in a RWD car will be a handful on the track so just go into it slow until you become comfortable with the track and the lines required.
oh man theres gunna be some hectic cars in there!!! though your a first timer
you drive with people with similar experience not power. youll be in the 1:25 section for the first couple runs, then move up slowly till your in the right place
pretty keen now mannnn
Matt, few tips.
:laugh:
Got it! Trail brake, apex, gate!!! Easy
Will be awesome man!! I am getting an SAU NEWCASTLE sticker :P
Lol no idea what trail braking is, but if that means brake before turn-in while car is pointing straight, then yes!.
Your a clown!! Your giving advice and don't understand what it means? Dumb ass :P GTFO
Dude, I actually read what Matt said as Newcastle Skylines sticker as well =S.
Summoning GTR-34A, are you going to the trackday?
Have you got shit in your eye again?
LOL, I'm a lot more confident in my driving ability, than my ability to install a $70 shift knob =D
Got it..... You can't drive and love the knob?
