cheap but still out of my price range for the rotors haha. free is a good price :D
Check out the new Brakes Direct rotors? Ask Oweban about them, he's fitting some up...
Fark all.... Watching some shit on TV with the dogs lol (wondering if Chookie has killed himself via coilover yet)....
No he didn't kill himself
Gave him a hand and wouldn't have got the job done without a lend of a socket from my toolbox
Coil overs fitted as well as front castor bars
Good stuff! Bet he is smiling hardcore :D
Yep just have to adjust the left front two turns and tighten all the bolts and job done but h can handle that
Car looks mean now
Awesome...
Missed abit in here.. Been flat out as usual...
Going shorty to get my coilovers fitted too, getting very keen!
Not sure if we're going to bother with a mini cruise this Arvo though, weather is looking average, and I'm not sure on interest?
Will still try and organise a time and place if people are keen..
yeah not sure if ill be able to come or not. if your keen swing me a text.
god dammit... was gunna to oil cooler this morning but i left my socket set at work...... MI NEED MOAR TOOOOOLS
anttttttt think i could borrow your brand new socket set tomorrow/sarvo? :P
Lol u can do it here if you need to borrow tools J-Rad although it's a bit of a hike... Have u checked all the lines fit? Made a bracket etc? Don't undo anything until you do that, also is it 100% clean and been sealed?
it has a bracket made to suit rb25s lol, not sure if itll fit a gtt but ill work something out.
nope it has been sealed or cleaned i dont think? haha. what do i clean it with?
its been surrounded in bubble wrap for the past 6 months
Went into bowers suspension to get some prices on coilovers and the told me they were fitting some bc's onto a yellow 34 gtr which im guessing is you.
Let me know how they go for you, im looking at getting the same ones fitted. Did they fit any other suspension components like bushing etc?.
It looked real good and he said he was happy with the service.
Pretty sure they adjust everything for you and I can't see why they wouldn't do that
Just letting you know cause he mightn't see this for a while.
Are you new to the forums?
Been a member of the forum for over 4 years but i never post, i only come on if im looking for something or need a question answered.
You may have seen me getting around newy, i have a white pearl r34 gtr. owned it for just about 5 years now.
Nice, I think I've spotted you too :thumbsup:
Bring her out on the 21st mate, plenty of 34's going and a good chance to get some good pics etc
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
