Thanks man, appreciate it!!!!
Benji real cars fit Pads and Rotors..... Wtf is a hardware kit? Are you fitting a bench vice to your control arm?
The shims and clips things are the hardware kit...
Heres a hardware kit for S13.
Once funds permit, I'm going to be ordering a vented carbon fibre bonnet from japan
Not really in a hurry for rims as Ive got a pretty much fresh set of KU36's on that set of rims atm.
And coilovers etc are going in in January. From where its at, only needs to be lowered 10mm in the rear and then the control arms will be parallel all round. So I dont negatively affect handling, I'd need to spend more money on things like roll center adjustors if I decided to go any lower than that.
yep - welcome to the joys of gtr ownership.
nice price on the 9's - thats basically what i paid for my -5's (which are usually a few hundred cheaper)
Edited by wedge_r34gtr
Come over to WA and keep me company :-)
What is the work situation like over there?
Could realllly consider it in the new year.
As for car stuff I saw Paul today and got the motor back on track. Also picked up a nice shiny catch can/washer bottle
Mjh, I washed my car today and just polished it afterwards....
do you have any tips on detailing?
Best thing you can get for detailing is a Concours 900 RO kit.
Car looks good as is just get a good sealer and wax to help protect the finish. Check the detailing thread and also check out the Waxit site for quality waxes etc
Work's pretty plentifuly, lowest unemployment rate in the country.
i know that catch can, its really shinny :-)
Did you get a water pump? Paul kept hold of my spare N1....
Yeah just went with a VL pump.
N1 pumps are more for higher revving motors aren't they? EG drags tracks etc
I'm giving some serious thought to a different job.
The one I have now is good but not enough work or pay
Some guys manage to do 12 hour days regardless of how busy or quite it is an I seem to get the easy short run most days
http://www.gumtree.com.au/s-ad/hoxton-park/cars/nissan-skyline-gtr-must-see-goin-cheap-1995-model/1009072657
14k maybe less could be mine this weekend.
thoughts, fears, loan??? haha
I could very well be wrong but don't GTR's have a BNR prefix for the chassis number?
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
