3 pumps.
Shit be craycray.
No more farking around and NO more breakdowns due to a damn single pump! So 3 pumps, 3 fuel lines, 1 surge setup, 2 billet filters, duel entry feed and new reg! No more playing :no:
Double mate,
Dunt choo no mathes?
Ill work on triple next year :ph34r:
Bullet proof?
Wanna get Cori to test that?
Yeah i might give that test a miss! As i dont think Cori will miss! And E85 burns VERY well.......Ask my mate JJ, he still has scars to prove it lol
Hey guys,how bout this heat.
Saw 41 in my travels today,still scorching in tarro now,
tommorow is spossed to be even hotter.Me stayin back at the ranch in air con comfort.
Too hot to be carting my lil doggy around as well.
Sunday will be cooler i hope. :)
Aaaand I'm home
Had a safe trip, trailer tows well
Tired now but going out shortly to play poker and do stuff with Melisa
I read that as do Melisa and Poke-r..... But I am dodgy I guess
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
