found a bike tweety matt :)!!!!!
http://www.gumtree.com.au/s-ad/newcastle-region/motorcycles/2012-ninja-250r-special-edition/1011680618
he replied to my want to buy add saying 5k and i said i cant go over 4k but ill let him know if i change my mind and he said it needs to go asap so i said 4500 and he said yes! hes dropping it at my house tomorrow!!!
lets get these licenses chook! hahaha so pumped!!!
really want to come but the skyline is way too sick to come out. it sounds like a subaru until it warms up and then it backfires to the point where i got pulled over and severly warned. and my power steering needs new fluid and im too poor for that. maybe next time.
Doesn't sound good
You checked plugs and coil packs yet?
it all started after i pulled the injectors out to check them. they need replacing (plastic bit on ones cracked) and yeah ignition is all fine, its a fuel issue. not including air as ive replaced the oily air filter and cleaned out as much junk as i can.
Hey guys, im new to SAU. Finally got my track 33 in a road cruising condition. Looking to get more involved with you guys from around the newy area. Ill keep an eye out for your next meet and tag along.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
