Sweet well have a bit of a crowd! Who's Tim??
So far we got
Me ant Ben mat benji Ben(xd) and Tim?
The cost of the harness for both was like $190 from ebays, and yeh feels like some fast and the furious shit strapping ur self it. The best one tho is when u roll through maccas drivethrew at 2am with a racing harness on in a GTR, the Jaws drop.
Total spent on the car now im around 15k still, but thats only stage 1 and i still need to do ECU clutch fuel pump and injectors.... Once its paid off and daily is aquired i will be putting in a half cage, rear seats out, big single, Fuel system ECU ect. lots of $$$$$$ and full engineer for the street. But that is along way off just pipe dream for now.
BTW does anyone know of an RB26/30 that has been stolen around newie/coast just saw one posted forsale saying it has no engine numbers.
PUTTY ROAD CRUISE
meet at beresfield bp at 9am (turn right at the round about at the end of the f3) where we met for martins cruise to singleton.
well discuss the route when we get there, aim is find all the fun bits on putty then find a turn around point, probably that petrol station thingy on putty.
found a bike tweety matt :)!!!!!
http://www.gumtree.c...tion/1011680618
he replied to my want to buy add saying 5k and i said i cant go over 4k but ill let him know if i change my mind and he said it needs to go asap so i said 4500 and he said yes! hes dropping it at my house tomorrow!!!
lets get these licenses chook! hahaha so pumped!!!
have you got your bike license yet?
Grose!!! I'm going to Parramatta today to go races.
45 DEGREES!!!!!!
Yep.... At 22psi it blew the tank off my radiator.... Fail!!!
Went mental prior to that lolz
That really sux matt,your having no luck with the car atm.
But yeah, +1 for HG.
Did someone say 3L bottom end rebuild? :woot:
no way 30! if it has done the HG, its only done it because its made the head studsa little longer.... New HG, ARP fittings, strap it down again and enjoy.
might have just been a brittle old top tank. I've had one crack before.
lol, i know! i'm only giving him idea's :thumbsup:
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
