Sweet well have a bit of a crowd! Who's Tim??
So far we got
Me ant Ben mat benji Ben(xd) and Tim?
The cost of the harness for both was like $190 from ebays, and yeh feels like some fast and the furious shit strapping ur self it. The best one tho is when u roll through maccas drivethrew at 2am with a racing harness on in a GTR, the Jaws drop.
Total spent on the car now im around 15k still, but thats only stage 1 and i still need to do ECU clutch fuel pump and injectors.... Once its paid off and daily is aquired i will be putting in a half cage, rear seats out, big single, Fuel system ECU ect. lots of $$$$$$ and full engineer for the street. But that is along way off just pipe dream for now.
BTW does anyone know of an RB26/30 that has been stolen around newie/coast just saw one posted forsale saying it has no engine numbers.
PUTTY ROAD CRUISE
meet at beresfield bp at 9am (turn right at the round about at the end of the f3) where we met for martins cruise to singleton.
well discuss the route when we get there, aim is find all the fun bits on putty then find a turn around point, probably that petrol station thingy on putty.
found a bike tweety matt :)!!!!!
http://www.gumtree.c...tion/1011680618
he replied to my want to buy add saying 5k and i said i cant go over 4k but ill let him know if i change my mind and he said it needs to go asap so i said 4500 and he said yes! hes dropping it at my house tomorrow!!!
lets get these licenses chook! hahaha so pumped!!!
have you got your bike license yet?
Grose!!! I'm going to Parramatta today to go races.
45 DEGREES!!!!!!
Yep.... At 22psi it blew the tank off my radiator.... Fail!!!
Went mental prior to that lolz
That really sux matt,your having no luck with the car atm.
But yeah, +1 for HG.
Did someone say 3L bottom end rebuild? :woot:
no way 30! if it has done the HG, its only done it because its made the head studsa little longer.... New HG, ARP fittings, strap it down again and enjoy.
might have just been a brittle old top tank. I've had one crack before.
lol, i know! i'm only giving him idea's :thumbsup:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
