if you have free time feel free to come work at my house for free, youll learn heaps of trades, painting, horticulture, carpentry, electrical! hahaha
nice one, i spose they wouldnt be out to much on monday nights, thursdays-sundays are bad haha
hahaha yeah. well im thinking bout asking around for even some unpaid work at a mechanics before uni goes back and maybe a day a week.
and we havent had any trouble yet and we've been running meets for about 6 months now. supprisingly ive been pulled over alot in my lancer (its dead now) but not once in the skyline.
Your lancer is dead?
So you're the guy who wrapped his Lancer around a tree at Sugarloaf?
hahaha well dad taught me pretty much all his electrician skills but im no professional. plus i grew up on a farm so im an all rounder.
thats the reason we meet early in the week. before i got the skyline i use to hang out with the foreshore and kooragang croud but now i avoid it like the plague.
and no that wasnt me. my fevo (fake evo 6) got destroyed out near wollombi. came round a bend and there was a wombat on the road and i swerved, went up an embankment and smashed the front end on a rock and then it got trailered home.
haha good stuff, my dads an all rounder an ex mechanic so im a bit of an all rounder too haha.
yeah i hate those fags haha, everyone here knows how much and all of them dont like being called fags so they dont like me either hahaha.
man when i was scouting for my cruise i nearly cleaned up a roo!! lucky i was in a skyline i swerved at 100km/h haha, martin was in the car with me and didnt see the roo so needless to say we both needed a diaper change!!!
so a friend sent me a link to how to diagnose no start, no crank issues. and we went through his first couple of steps. the next one is to check which cylinders are up and down and if my case follows to the one in the video (on a civic though) it looks like my motor is toast. think if thats the case i might need to go on my japan trip early to relax. but anyways tomorrow will tell us. i dont know why my motor would die seeing as we serviced it completely 3000km ago and it was running fine when we took the fuel rail out and 24hrs later when we were putting it back together its buggered. and yes i talk alot.
and yeah i didnt have much room as my mate had stopped about 10m infront of the wombat in his 80,000 dollar bmw so i figured stuff the lancer and put it up the embankment. either way i came out on top seeing as i own a skyline now.
hmm did you touch any timing? timing belt? cam gears? anything in the head? you sure you dont just have a clog in an injector or something?
when you turn the key does it try and start or just do nothing?
thats ok i do too some come chat more often!!
ah good choice haha
so tries but not for very long?
to measure a battery you hold your metre on the pos and neg while starting it, it will always drop usually to around ~8v, less then that, theres your problem, give it a try first man.
if it sounds like its trying to crank but then just fades out and stops trying id say defs battery
when you turn the key it makes the sounds that ud expect if u had a flat battery. but i have 12v at the battery. and the injectors shouldnt be clogged seeing as i just paid 120 bucks for them to be cleaned properly.
where u from daniel?i could probly come have a look and give u a hand gettn it goin
im in birmingham gardens. it was suffering from hydralic lock which has been cured by accidently spraying a mate with petrol (he is okay now). the new problem is it is cranking but not igniting. so im thinking when the bosch spark plugs got submerged in water they died. we've called it quits for today. it also has a semi flat battery. its at 11v with the ignition off and drops to 3v during cranking so weve been using the forester to jump it. so at this stage im thinking ill invest in a set of ngk plugs, some new oil and then i need to get some fuel to my place from the servo as im running too low to make it to a servo when she does come back to life. also has anyone had any issue with bosch plugs?
another update. so i figured out my fuel in and out was backward on the rail. so i reversed it and then tried to jump start her. cranked for 5 seconds but no ignition. so i gave up. second attempt it hydralicly locked straight away. any ideas?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
