hahahahahaha you always chime in at the best time Martin
if he's got black rims at 17/9 I might be keen ;)
He has custom sprayed gunmetal rims in MAN size, none of this faggy 17/9 crap lol
went for a drive on old Pac today. was pretty fun, only did the 60k zone as I thought that was the fun bit.. :( turned off just before the fun bit!!!!
very different drive style. it's like... skyline kicks out, take your foot off to straighten. evo kicks out, keep foot on and steer your way to safety? haha very strange. it also 4wd drifts and slightly oversteers which seems really easy to control.
fun fun.
did we make a date for Wooten?
fun fun.
Why do i need a date ya kent? lol
No i dont think a date was set as yet... Make one!
Sorry i couldnt answer the questions yesterday man, was covered in concrete lol... So i just forwarded the messages etc!
hahaha how funny.
I can't just pick a date out of ny head! I have to ask the boss first.
all good man :) I found out some stuff :)
mainly timing belt isnt done! :( so I'm gunna do 100k service, diffs oil, transfer oil, gearbox oil, engine oil, and the brakes need doing so pads, fluid, gunna pull apart calipers and clean em, rotors need a SLIGHT machine cause there's a shudder in them.
f**k it, cause race car ay!
that should all last me a Couple years though I hope :)
hahaha how funny.
Faaarrrrrrrk
And here I was thinking you got the bargin of the century but it needs all this wok done
And the bootlids needs to be fitted properly and all
it's still is a bargain, I'm just over cautious.
all those parts should only cost around 800 bucks. so once I sell all the skyline parts I'll only be 800 in the black. I came out even on the transition of cars. or around 500 bucks more haha.
lolololol oh man that boot fitment!
I have to do all that shit anyway if I want to race it, everyone should.
Hellllooooo nsw what's going on down in this backward time changing land of hipsters :ninja:
Jarrads come out of the closet an purchased a banana Evo
I'm still breaking cars and playing Bob the Builder
T4nk had a stack
Chookie needs more gate!
NSW is still full of cops and they are all still kents!
tank had a stack?
"I'm not coming out the closet so go away"
He put it on the 34 thread on FB which you cant be a part of because you are ghey!
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
    • Looks better than dusted paint, and also looks better than the old OEM one, much happy
