nah its not bad but its right of the flared bit of the panel so its pretty noticeable, paint is fine, just little dents, could probably be fixed for cheap idk.
never got a bloody mark on the skyline (off someone else hah)
spewing man, I noticed today someone has reversed into one of my doors because theres 3 dents it didn't have.
people are f**king scum bags
Maybe you should get a brighter colour? :P
https://docs.google.com/spreadsheet/ccc?key=0AjSl31W2Yt-1dFM3bnRBX2QybFpLdHZOQ05pZXlNOGc#gid=0
VERY INTERESTING!!!!
GO GO EVO!!!! no 7 but 8 is just as good, bar is set, I gotta get atleast a 1:08 now hahahaha.
times are from professional drivers and standard vehicles.
ant will like the fastest car
thatll be me going past you benji haha!
though I wont need the gutter.
im going for a cruise on sunday if I can get my oil temp gauge in by that time which I should be able to.
ill swing everyone a msg if I am going, I yhink a few people were keen.
hopefully my brakes show up too so I can bed yhem in a bit
None of my gauges are Hooked up J-rad... Just sitting there all homo :( Still limiter bash it cus I can lolz
Depends when and where the cruise is?
Yeah i am on short range duties too! Full tune should be complete by the start of May... I might have to sit this one out so i can be ready for some track action in May and June...
I would be doing the oil cooler regardless, high boost on pump fuel means heat heat heat!
yeah I really cant be f**ked but:( hahaha
probably will
You will want to be f**ked................. Wait.................. This is not going well......................
What i meant to say is that you would rather do it now than overheat the engine :P
yeah thats true. sigh gotta take the bumper bar off... dem panel gaps brah. benji will hate me!
Benji has the biggest panel gap on the planet!
So does his 2 gayz from toe KO edition nugget from accident damage lol
So if this Homo cruise isnt happening do you all wanna catch up for a feed on Sunday somewhere? Cruise to the bay for Pizza? Hoggies? Stroud Pub?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
