Lol yeah well you are now driving a steam roller :blink:
The really twisty bit between Buckets Way and home was good BUT a lot of crap roads for that small patch of fun!
hahaha yep.
have you driven from dungog to stroud? stroud hill road i think, there is a really twisty bit, plenty of hair pins.. crap roads eaither side but that section is fun. and the stretch from gresford to dungog is also pretty good, again a few real tight bits which is really fun, but crap roads either side again.
the good thing on a bike is the road dont need to be quite as good to have alot of fun on them, especially when your learning!
haha the wide body does look sick but bit un-nessesary for me atm hah. 200kw isnt that hard to control.
Its an Evo, point and shoot ;)
hahaha yep.
Yep that is the road i meant! Carmen to a screeshot of the GPS and its just a spaghetti road!
It was fun in the 34 but was still a bit bumpy as the front would bottom out under hard braking and cornering! (Of course doing the speed limit the whole time)
need to get a bike then? ha
Hmmm...
Too Complimentary :P
haha that looks mad!
i dont see a problem?...
:laugh:
Nah, my sister was always trying to get me on a bike but she does enough damage for both of us, not sure if you saw but it looks like she wrote off the ZX10r finally...... well.......again!
did see something like that on fb... not good.
she must go pretty hard?
Keep it clean! Its my sister you are talking about :domokun: lolz
But on a bike she has no fear! :no:
Just got back from the 11 hour drive getting the car.
It has a sticky fuel gauge so we played it safe and refueled every 200km's. To my surprise with highway driving + a bit of stop start in Sydney it managed about 9-10l/100ks...
Is it just me or is that pretty awesome for a car with 330rwkw. We punched it a few times here and there as well but mostly just cruising.
Where did you pick that up from?
330rwkw sounds like itd be a good kick in the pants!
Got it from Junee mate and I have driven it up to Port Macquarie to be stored at my Parents house for the time being.
I am pretty stoked on it, its in very good nic with the only issues being a couple oil leaks (cam cover seals and what I believe to be the oil drain pipe off the turbo). Will be getting onto those when I can.
I also came across another strange occurence with the car just now when I was down in the garage admiring my purchase haha. I made a thread here if anyone wants to have a look and offer any info/advice.
http://www.skylinesaustralia.com/forums/topic/426150-fizzy-sound-radiator-related/
Also while Im at it, is it safe if I degrease / use a gurni on my engine bay? I just want to degrease it the best I can so I can spot exactly where these leaks are coming from. Whats the best method
Edited by Bennis
people do gurni but you can try to avoid electrics all you like and you may still f**k something haha,
I pressure pack degreaser things if im looking for a leak etc then run it to see where it leaks from, more direct and safer.
as far as cleaning I think people armorall the engine bay? spray on wipe off.
gurni could chips paint on engine covers or paint in engine bay so id play it safe and do It the hard way :)
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
