on house stuff martin, i signed contracts on a place today, fingers crossed everything goes through over the next week or so.
Oh epic! More good news!!!
Can't believe no one has posted in nearly two weeks
Melisa is now looking at houses to buy with her son
She found one that has a twin carport with roller doors off the side of the house but the best bit is the two car garage in the rear yard
She says I can keep Racecar in there as well as bits and pieces. God I love that woman
So ive been advised of a police blitz on this weekend in the newcastle area. Highway cars from Sydney central coast maitland and newcastle will be in the area. Be careful guys. They are gonna be everywhere
i think your meeting all of us tomorrow mate
me in the yellow evo,
ant in his yellow gtr
martin in the tommy kiara gtt
mat in his hoon mobile
:no: no hoon mobile :/
Hey guys!
I'll be sure to keep an eye on this!
I live on the OTHER side of sydney, but with the M7 I dont mind the drive to the central coast.
I missed this years megalong valley =(
Changing the o2 sensor this weekend, poor R34's been running like crap.
  • 3 weeks later...
Bump to the top
Should have keys for house on Friday so am happy bout that
Car is going fine
I survived a trip to the snow and back
Melisa is away for the rest of the week till Sunday
Racecar still in bits awaiting more go faster parts to arrive
And that's about all the news I have
What about everyone else
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
