Benji the fastest road registered cars time is 1:05. It's a fully worked integra.
You will not get 1:08. Youll struggle hard toget 1:15
And considering you've driven your car once I think you might get 1:18
They vary a little the 17 inch is 400!
Pm Cpd for prices if your a nsw member :).
If your not pm him anyways and say you'll be joining soon the price pays for your membership, not to mention events cheaper
J-Rad where you doing the brakes on your car r was that someone else?
Can do them here if you need guys, once my car is out of the way... Should be on the deck by Sunday night
Probably my garage. I'll have to check out how much space is there.
Wanna have a brakes day? <3?!
Haha true benji. Maybe WA has a similar thing??
Still get a price. 60 bucks membership surely a bigger discount then that
You'd be surprised..
i'm moving to Perth in bout 3 weeks - im already working there...so a WA membeship is probarly the better option. lol
WA = :no:
No E85 = No fun :P
one of the united stations south of the river was meant to have it - I checked it out this arvo after work - no deal :domokun: :domokun:
I'm going to try to contact someone in united and see if we can get it or at least if there got any plans to set it up over here
Edited by wedge_r34gtr
PM Hanaldo, pretty sure he has done all the research mate!
Hmm yeah Righto, umm I'll let you know when I got em? Maybe next weekend? :)
I want them on for the cruise to bed them in!
Yeah just let me know :) I gotta get mine in too BUT another 3 weeks or so before I get the rotors :( fail.....
Gotta bed that monster clutch in :P
Hahaha very good!!!
Wish I could get rotors... Though... I have gtrs on the brain brah! Since yesterday fark in keen!
Yeah then you will just need an anchor and bow thrusters...
Sigh... Hahaha hvent even got the f**kin thing and I'm already sick of it haha.
The gtrs aren't boats ya fool!
It's still a 33! It's more of a ship I guess as its bigger :P
to be honest i don't really need tires atm -it was just a good price. i'm sure there will be another deal next year
i'll keep that in mind and send him a pm. I'm pretty keen to go green
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
