All.
I have for sale my spare RB26 as per below. Comes complete from sump to turbos which are HKS 2530s (pics included).
I've had this motor for quite a while from a GTR I had imported a few years ago. I was planning on putting the motor into a side project, which has now been canned in favour of buying a house.
Don't buy a stock motor for $3500-$4000 and then spend another $2500 upgrading turbos, Simply bolt this great condition motor in, wind up the boost and see a easy 360-400rwkw with the rare and much sought after HKS 2530s :thumbsup:
Details as follows:
- Motor came out of a running '96 R33 GTR with ~120,000kms on the clock. Dyno'd up and drove fine with around 280rwkw on 12psi from memory.
- Motor was comp tested immediately before taking it out for storage, results returned 155psi-160psi across all cylinders by Racepace Motorsport, well within factory tolerance.
- HKS2530s & set of split dumps are on the motor.
- Plenum has a new gasket/resealed as there was a slight leak.
- Plenum & cam covers have been freshly crinkle coated.
- Low KM R34 GTR stock injectors installed, freshly flow tested/cleaned. One of the stock R33 ones were leaking, so full set replaced.
Price: $5500 compete
Price for motor (minus turbos only): $3100
Happy to ship interstate at buyers expense.
I will separate turbos/dumps & motor. PM for further pricing & discussion.
post-709-0-25258600-1339658710_thumb.jpgpost-709-0-08875900-1339658716_thumb.jpgpost-709-0-05024100-1339658722_thumb.jpgpost-709-0-68919400-1339658727_thumb.jpgpost-709-0-71689400-1339658732_thumb.jpg
Contact via PM.
Thanks
https://www.sau.com.au/forums/topic/402550-hks2530s-w-complete-r33-rb26-engine/
Still here.
Will consider splitting up the Turbos/Dumps & the motor
If interested in either part - PM me. I will only split once i have deposit for each part.
Not likely to be around that long.
Have a buyer for the dumps.
Potential for the turbos (if the motor goes)... So just need a buyer for the motor and it’ll be split up no problem.
First to cough up cash, wins!
Sure is.
Lots of PMs, lots of low ballers - the price is very reasonable for what you are getting, you don't find cheaper.
So don't bother sending a PM if you intend to ask for "best price". The best price is listed given it's priced to sell.
Turbo & dumps are sold pending pickup later in the week.
Motor here now - $3100 ONO
Comes with all the oil/water lines for turbos and full intake/exhaust side still. Literally just minus the turbochargers.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
