Official event: Shepparton overnight stay and DECA fun day cheer squad cruise
I still come if someone out there wants to enter me as a second driver!! Come on - you know you want too!!
Im soo bummed my car isnt available :D Was looking forwards to this for ages.
But Im a crappy spectator (well Im a crappy driver as well but hey!) so I couldnt bring myself to go all that way just to watch.
Because I don't even have the ute at the moment - its in getting some touch up work so I can sell it.
And the wife wont let me use her car - and Gerlad just sold his car last Friday.
So the gods are against me.
Hey Andrew, I can let you use my Gemini if you like.. It's registered. 2 Litre, cam, head work exhust, RPM clutch lowered, 17" rims. No LSD, but I could swap the diff to a locked one if you wanna give me a hand. Goes ok, but nothing compared to the line. We might even swap on the day.
Let me know ASAP.
I have had a change of plans in regards to accomodation. Was staying at a friends in Merchison, but he has other stuff on now. Does anyone have a spare bed in a room?
Otherwise, James can you give me the number of this hotel so I can try book myself in..
Ta, Chris.
Chris / Jarrod,
Guys - thanks both for the offers and at this stage I am still keen to come up. The tough part is that it seems now there is a slim possibility my car may be ready on time. Although Im not holding my breath, but if toyota have gear sets in stock then Im in luck. But I won't know if my car is going to be ready until late in the week so especially to you Chris I couldn't say yes right now - although the idea of taking the gemini has some strange appeal I must admit! lol.
But one way or another it looks like I will come up anyways so if still need to beg for a drive I can do so at the Shep Pub on Sat night. :D
Chris - got your PM, rang hotel - all good.
Spoke to Al - he has the details of the hotel also.
I still at work - waiting for marketing dept to ruin my weekend again... but at this stage i still see y'all this arvo.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
