  • Replies 81
haha I like this bloke. He gets where I'm coming from. Great minds think alike hey Tai1or Made? Burn me bitches haha :thumbsup:
http://www.skylinesaustralia.com/forums/topic/402108-bodykits-in-perth/page__fromsearch__1
thread is pretty sweet, post pics when ur done with LED's, always wanted to do the same with my car, im useless with DIY electronics though.
how much would u charge to set up the same system u have in ur car under my 33 FE4R?
do want.
on topic, keep the B&W bishes coming!
hey maybe instead of spamming the same generic pics of floozies, you guys could stop posting crap and give the OP some constructive advice? Serious amounts of fail on this page.
OP: do what you want with your car, haters gonna hate. LEDs would look cool, I think the blue gives the best 'street racer' look personally, esp if you can thread some up through the front bar and intercooler.
Have you thought about getting some vinyl wrapping on the panels for that real tokyo drift look? it'd be awesome!
You have a profile pic of a young asian boy and a donkey....... and your saying theres a massive fail on the page...hmmmmmm.....
wasteland this already, its only going to get worse
What do you mean going to get worse?! This is the best thread out!? TROLOL. +1 Million points for the polka dot panties! haha.
@bozodos - it was bound to happen. Not to mention I LOVE floozies so it's all good ;) Also I don't really want blue. I've got a B/W theme going with my car anyway. Also I don't yet have an FMIC :( It's on the to get soon list though. Thanks for the input though instead of coming to a thread about something you don't like and posting something useless. Why bother coming to it at all? Like a sir!
Don't install a front mount, you'll have no room for the 18" deceptecon badge.
it's Wotaken brah, lern2japaneseculture
no probs OP, sometimes I feel that there is too much negativity on these forums and a real conservative streak instead of encouraging people to do something different
lol been to japan twice brah.....Im more than happy with my real knowledge of japanese culture vs japanese pop culture (and aussie trends of that).....
Also you talk of doing something different....what 5 terrible years of car culture and trends that followed the release of fast and the furious wasnt enough undercar leds for you lol....point is that its been done a gazillion times and it was horrible when it was happening...let alone again
Edited by sinistaGTR
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
