  • Replies 91
Hi Spiro,
I'm missing one of the triangular trim bits that covers the seat belt bolt where it attaches to the b pillar - don't suppose you have it lying around anywhere?
Also, how much for the seat belt buckles that attach to the seat? Delivered to Perth metro (the seat belts I got off you don't fit mine lol)
Cheers,
Steve
^Called C Pillars ^
Diificult to get ones that the backing isn't cracked.
If they have ever been taken out withoiut extreme care they crack.
Thanks for that. Mine cracked without taken out so they might need a replacement. New one cost too much tho.
Yep just paid $160ea from Just Jap (only one set left now), and about the same from RHD (without shipping !!).
HI all.
PM's have been sent.
Does anyone know where the marking and what they are on stock diffs? i know the covers not stock but i still need to pull it out and have a peek.
Cheers in advance
Spiro
HI,
Im back on to stripping the car.
So here are some more pics and prices
Rear Seat belts and buckles $80
Attesa 4wd pump – $120
Attesa 4wd reservoir $40
Peddles - $15 each or lot for $30
Charcoal canister $25
Power Stering canister $15 - sensor lead cut/missing
ABS pump - $80
Drivers side 1/4 glass with rubber $80
Passenger side 1/4 glass NO rubber $40
Dash - $80
A Pillar garnish - $60 pair - Drivers side has 3 holes from single guage pod. will suplly pod also.
Steering column plastic - 4 parts - 50
Boot rubber seal $ 40 Perfect condition
Door/window seals - $ 20 Each please look at pics
Centre vent - $40
Heater/blower/AC boxes - $20 each
Tail Lights - no covers $70 each
More stuff to add.
Rear Cradel Complete
Cradle/Sub frame
Diff (excellent condition)
Half shafts
5 stud hubs
Gtr calipers + pads
Disks
Handbrake assembly
Handbrake leads
Camber arms
Traction control arms
Lower control arms
Tailshaft
Hicas cancel bar
Sway Bar
$800
Great upgrade for a s13 180....
HI,
Parts still avalible
Fuel setup from page 1 - Price Drop - $700
Doors - Price Drop - $150
Stock R32 GTR twin turbos - no dump pipes - Price Drop - $100
Center Din Gauges Price Drop - $40
Boost Sender $25
Side mirrors $50 each
Door cards - Price Drop - $30
Under dash trim with fuse cover - has a little glue residue on left side Price Drop - $20
Front sway bars with links, brackets - Price Drop - $30
Side mirrors - Price Drop - $45
Side Kick pannels - Price Drop - $15
Boot lock liner top bit hard plastic linner. - Price Drop - $15
Driver side rear Seat belt and buckle $40
passenger side rear Seat belt buckle only $10
Attesa 4wd pump - Price Drop - $110
Attesa 4wd reservoir - Price Drop - $30
Peddles - Price Drop - $10 each or all for $25
Charcoal canister Price Drop - $20
Power Stering canister - Price Drop - $10 - sensor lead cut/missing
ABS pump - Price Drop - $60
Drivers side 1/4 glass with rubber - Price Drop - $60
Passenger side 1/4 glass NO rubber - Price Drop - $30
Dash - Price Drop - $60
A Pillar garnish - Price Drop - $50 - Drivers side has 3 holes from single guage pod. will suplly pod also.
Steering column plastic - Price Drop - $40
Boot rubber seal Perfect condition - Price Drop - $30
Centre vent- Price Drop - $30
Tail Lights - no covers - Price Drop - $60 each
Diff cradle complete $800
Accelerator cable - Price Drop - $25
Front Windscreen Moulds - both - Price Drop - $20
Petrol Flap and cap $20
Boot/Fuel leaver with plastic - $15
Rear windscreen wiper motor - $25
Internal roof lights $15 each
Foot rest - $10
Boost Solenoid Boost Valve Sensor $40
Gear stick rubber boots and ring - $25
Aircon controller $50
Boot hinge spring system - $25
Windscreen Wipers $10 each or all for $25
Recirculation pipe $10
Std blow off valves $40
Intercooler pipe left and right ends $25 for both
Glove box $20
Intercooler Brackets top and bottom - note top ones not in pic - not sure what the other ones are $30
Stock ECU $60
Attessa ECU $60
HIcas ECu $60
Stock amp $20
Rear windscreen demister controller box $15
Drivers Side Qtr pannel - Has a liitle rust, I will sand back, and give pics $200
Roof $150 pics to come.
Afew more to add later.
Thanks
Spiro
0414 509 399
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
