Channel 10 feed is up and down, but I am enjoying streaming it to my TV from iPad, great to see so much of Le Mans this year, can't believe those Audi's both so close together.
Whoa, that was a horrible accident, hope he's ok.
Edited by cherring
Very depressing watching LeMans this year, was meant to have some of my design work and sponsorship out on track ( again ) but the deal fell through at the last minute :(
Driver attempts to repair the delta wing to get it back to the pits.
378 laps by the winners
5151.8 km distance covered by the winners
40th victory of a French driver
33 pit stops for the winning car
29th victory for a German car
29th victory for a closed car
27th victory for a German driver
21 retirements
21st victory for Michelin and 15th consecutive
12th victory for a car with race number 1
11th victory for Audi (00, 01, 02, 04, 05, 06, 07, 08, 10, 11, 12)
8th victory for a pole position car
8th victory for a team that won the previous year
7th victory for a diesel powered car
5th the position of the best rookie in 2012, Marco Bonanomi.
3:24.180 : The fastest lap of the race by Marc Gené
3rd consecutive podium for Lotterer-Tréluyer-Fässler
3rd consecutive class win for Julien Canal (GTE Am).
2nd consecutive victory for Lotterer-Tréluyer-Fässler
2nd victory for a Swiss driver
1st victory for a hybrid powered car
1st victory for a car with non-permanant 4 wheel drive.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
