For anybody wanting to try a twin rear setup, here is one i knocked up yesterday.
So, in this example, im keeping the centre muffler, adding a new flange about 200mm behind that muffler, and bolting this onto it.
First thing was to replicate the original bumper cutout to the drivers side.
Its all 2.5" parts... flange, single to dual collector, all 2.5" mandrel bent tube, a dual 3" tip on each side.
under the car, it clears the breather canister but require removal of the other part that vents into the chassis and rerouting of the pipe that fed it.
Noise level with this setup is a bit too much in my opinion, but my partner says its ok. i find it drones too much between 1500-2000rpm. A bit like a didgeridoo.
but anyway, i just made it as a trial... will try adding a 12" long glasspack resonator before each tip later. will need to relocate that canister first tho.
Edited by Deep Dish V35
https://www.sau.com.au/forums/topic/402809-twin-exhaust-for-sedan/
total including welding wire was $300
id rather just draw up a plan of it than fabricate another hahaha
http://img.photobucket.com/albums/v716/sc850/random%20forum/98287b68.mp4
oh hahaha yep thatd annoy me too if it was visible..!
OK so now an update for this setup
it was too loud (for me) from 1500-2000rpm so ive added a pair of glasspack resonators. They are a centre muffler from an EF falcon, $45 each brand new, 2.25" bore, i had the ends put on a swage and expanded so they slip over a 2.5" pipe.
the result is... no more drone! Its louder than the standard muffler but quieter than the first design. i'd describe the sound as somewhere between VN commodore and BMW E46 M3.... an odd comparison, i know. unfortunately it has lost most of that VQ burble that you heard in the first video... changing the resonators for hotdogs might fix that..... or of course changing the main centre muffler...
the clearance issue with the vapour canister.... just need to install a shield rather than relocate it. the pipe running down the right side used to connect to the breather which i have deleted for now but will relocate elsewhere. There is at least 200mm of air gap above the resonators, nowhere near the fuel lines that feed the canister
and the video of it completed
http://img.photobucket.com/albums/v716/sc850/V35/twin%20exhaust/f2bafa8e.mp4
being a 250gt, id say its minimal, if anything at all.... with just straight pipes it broke into wheelspin much easier, but i doubt it was from a huge power increase.
the one thing i have noticed with both setups is a definite point in the rev range where the exhaust note seems to clash with something... its not a horrible noise, just sounds like 2 different notes at once...
still havent installed the plenum spacer either... but ive heard a rumour about a different plenum that has bigger gains which i'll do some research on.
  • 1 month later...
action vids
no noise when driving normally, nice note under acceleration
and yes all within local speed limits
http://img.photobucket.com/albums/v716/sc850/V35/twin%20exhaust/98637495.mp4
http://img.photobucket.com/albums/v716/sc850/V35/twin%20exhaust/06945b11.mp4
