I'd be getting rid of the dumps, cause I had the same dumps and the same issue. Since changed over to Midori dumps (but changed to -5s as well)
Oh I see....well that's the thing - I've been reading about peeps who swear by them and then others who're fans of the bell mouth style ones which are what you're using (I think).
So did you have a set of -9's before you went to the -5's? Keen to hear more about these xforce dumps and why they're not that good...I'd be happy to swap them over or even put my stock R33 GTR ones back on (I know people make decent figures on these too and also use them as upgrades on the R32's)
I use xforce split dumps - they're fine. 305kw @ 17psi on -7s. 16psi at 4000rpm. If anything you could go slightly backwards spool wise with a bellmouth as they produce more turbulence post turbine. Changing dumps is turbo out, so not only will it not help, it will be expensive for labour....
Ah ok - that's the divided opinions right there haha
Ah the swap isn't too bad - I've gotten it down to about 1 day's solid work now but don't really want to do it again! Those are some nice figures by the way - you must have an excellent tune! Yeh at this stage I'm just going to drop the cat and cat-back out to see if there's any difference. If there is, it's new cat and new tune time ;-)
I have -9s with HPI bellmouth dumps one of the biggest on sale. Running 330awkw 18psi full boost 3800rpm.
I don't think your dumps are the main issue, yes could improve with different ones, but as stated before drop the cat and check/replace it.
I had an issue with a previous "hi flow" cat that was causing a 10+psi restriction
Wow those are even more awesome figures! Ok, well tomorrow I'll drop the exhaust and see what she's like and post it up on here. Yeh 10psi+ seems like a massive restriction - I'd probably have something like this too.
But yes, we shall find out tomorrow.
Thanks for all your replies so far - most helpful in a time of great frustration!
i have 18psi by 3800rpm on hks dumps so problems for you there, also had an issue with blocked cat previously and car lost 40kw, check for leaks as well
I'm assuming you mean "no" problems there...are you referring to the split dumps? 40kw hey? Yeh I need to gain at least that much....really hoping to make close to 300kw to make all the money spent worth while!
Also guessing you already know but don't flog the shit out of it with the cat dropped.
It's not going to be tuned for the extra flow and power so might lean out at some points
Haha offcourse not. I've been talking to the tuner about this...about how much margin there would be for this. I basically plan on just giving it a gentle tap because I'll know right away if it's had an effect - that's how poor it's performance is right now. Then I'll be booking it in with the local exhaust mob to get a proper hi flowing cat put in place, along with a larger internal dia canon
Yeh tuner didn't know much about my turbos...didn't even know -9's existed in the 2860 range :P Mainly does bigger turbos and singles.
She's obviously gonna need a re-tune once exhaust has been rectified (provided that's the only problem and it's not something more sinister etc etc)
just curious, if the tuner dropped the exhaust on the dyno how would the gases get collected, from what i seen the fans or whatever that suck them up and deal with them are right at the back of the dyno room, so wouldnt that fill the room up with fumes???
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
