Forget bleed valve all together and get a good ebc. Your results sound pretty similar to mine ie. 13psi by 4k,and I have yet to figure out how they rate acts, but I dont think you have 15/16 psi acts, probably the same 9 psi units like mine.
Anyway wind some more preload in there......
Ah ok so you'd probably have the same kinda basic mods as me? They seem to ramp up very sharply after 4000rpm. What are you gonna do at your end to make them spool up a bit more than 13psi by 4k? Personally it's a bit too laggy...this feels like a big single lol, not twins :D
I suppose I could try adding some more preload...it's just that if I add too much it may spike over the max boost of 18-19 pounds that I want to run
Don, further to that - yeh my invoice said 15.something pound acts but hey u never know, may have to check the serial number.
I wonder how people make 16 pounds by 3800-4000 with these 9's
What actuators are they?? i think i missed it
I am using the HKS heavy duty adjustable actuators like THESE
adjustable cam gears will help if you dont have them yet and a good ebc
In the end the tune plays a big part
Basically same mods except I havent installed my cam gears yet and run std R33 dumps, but I run a profecb2 and it does help a bit keeping the gates shut until target boost is reached.
My intention is to wind in some more preload and use the gears to bring it down further as I believe 16psi @ 4k is definitely possible, but that will be a while still due to some technical difficulties :whistling:
I'll check this wkend to see how much preload I have on them now.
Don, Levinboy,
Hey nah mine aren't quite as chunky as those. Mine are the ones that "apparantly" come with the -9's...they're definitely firmer than the 1 bar ones I bought for my N1 turbos. I dare say that somewhere along the line the springs do hold 16psi but I know for a fact that even the strongest actuators (under 20psi) will crack down low....ie, they will budge a little.
Yeh I do have cam gears installed by the tuner wasn't able to make them make positive numbers. He told me he was very quickly making negative figures so I believe they're dialed in very close to zero on intake and exhaust. But then it also didn't occur to my tuner to add more tension to the rods. It would appear to me, that they only knew how to work the efpos machine! ....can you tell I'm still very bitter about it all?? :verymad:
Yup, I'm hoping that a re-tune and dialed in camgears will move the whole show forward by about another 500rpm. I've already gained about 1000rpm by tightening the act's....now it's the tuner's turn! Unfortunately I don't have an EBC yet.
Don, I think I have about 10mm now...the outer end of the actuator just touched the boss that the flapper shaft/spindle passes thru. You'll see what I mean when you check yours ;)
Can you please try a different tuner and then tell us if it is better?
That is the idea mate...was thinking Godzilla Motorsport. He only does tuning now...nothing else. One would assume he knows what he's doing and I've had him recommended to me a couple times now ;)
Anyone want to make some donations to the cause? :)
New tuner
+ A good ebc with stepper motor
+ adjust your cam gears
= winning
Adjusted, Fixed seens a bit incorrect and impolite as you are right, unfortunately I'd say you are going to have to fork out for a good EBC, preferably with stepper motor, as it will help keep the wastegate shut longer and help the turbos ramp up quicker, also by reducing the overlap of the cams it will let the motor make better use of what boost it gets and load motor up better which in turn turns turbos quicker, aswell by adjust when the exhaust valves shut will force the air out through the turbos instead of letting the exhaust pressure back into the engine
Fixed, unfortunately I'd say you are going to have to fork out for a good EBC, preferably with stepper motor, as it will help keep the wastegate shut longer and help the turbos ramp up quicker, also by reducing the overlap of the cams it will let the motor make better use of what boost it gets and load motor up better which in turn turns turbos quicker, aswell by adjust when the exhaust valves shut will force the air out through the turbos instead of letting the exhaust pressure back into the engine
Yeh the more I think about how it all works the more I'm realising that I will need a EBC. Guess I should start looking around for one eh? It would be nice to make at least a nice solid bar by 4000...that should equate to some good streetability for everything below 4000.....and fun times above 4000 :P
I wonder if the Haltech solenoid is any good? (I've got a E11)
Don, Levinboy,
Did you buy the turbos brand new or 2nd hand?? as i know (in mycase anyway) i couldnt get them with actuators for some reason hence why i bought the HKS actuators. Some people re-use the std actuators and have issues, just to rule out all possible issues :thumbsup:
The blitz ebc are good bits of kit just make sure you get the dual solenoid or spec r variant i believe, can pick them up reasonably cheap
Godzilla have a good rep from what i have heard anyway, Queenslanders jump in here thanks, NUR33 has his families white R32 drag car tuned there and the results speak for themselves
Once every thing tired and nothing makes a differences then you can have them removed send it to us for the FNT turbine setups which proven differences in response. I'm also personally interested to see the differences they makes on a GTR.
More info?
PM if you like!
For example:
.82 rear housing using identical chra. Standard V Type A FNT.
Use above .82 Type A V Type B FNT
The power to response trade ratio after compressor maximization is 1:10 means the lost of every Kws can be converted to the gain of 10RPMs.
Take example that ATR43G3 CHRA is capable of making 330rwkws pump, how ever based on factory manifold and internal gate restrictions it can only archive 280rwkws, resulting a dead weight lose of 50kws. Assume the maximum power level this turbo can reach based on factory setup is 300rwkws, I can configuration the fixed nozzle in my turbine housing for it to max out at 300rwkws while trade the dead weight power for 300RPMs of response, as shown on type B housing graph above.
Just buy a MAC valve off ebay for $50, half the price of the Haltech ones. I have a few here but they have 24v coils on them. (new 12v coils are $30)
Hey, that sounds alright. I had a quick look and there are a fair few on ebay. Will just have to check out how many people have used them and what sort of results they have been getting. But yes, the idea would be to let the E11 control it if possible rather than having a second little computer module for just boost control.
Yeh mate I bought these two turbos brand new from a trader on here by the name of Boostn Imports. He matched the price of the local shops in town and also threw in some gasket and stud kits.
As for the actuators....I carefully checked both of them with a pump and gauge. Footpump to be precise because then you can hold the pressure wherever you want to etc. I made sure both of them open identically etc. They "appear" to be working alright with the extra preload but cannot put too much on because they'll just overboost then.
Yep, the whole situation is screaming.....EBC!!! :D However, I need to check them out first (hopefully it won't take me 3 months like with the -7 vs -9's :no: ) and now MAC valves have been thrown into the mix too.
Hypergear, thanks for your comments....however, I have been assured numerous times that I'll be able to make the 2860-9's come on hard down low. There's a thread on here that displays what they're capable off so I'm not going to adjust the geometry of the turbos just yet.
If all goes pear shaped and I don't end up happy with the end results (for some reason) I'll probably just step down a (small) notch to -7's which were my original choice till I saw how good the -9's go. However, I don't want to go there right now as I want to give these -9's a decent chance to impress! 1 bar by 4k is good...I'd be happy with that :)
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
