Thinking Of Buying An R35...key Differences Between My09, 10, 11 & 12?
Hi guys,
I am considering an R35GTR and would like to find out the differences between all the available year models - mechanical, cosmetic and even creature comforts.
I'm also interested in hearing the opinions of fellow R35 owners on what year model is recommended and why?
Naturally, I will be modding the car and the 09 seems the most appealing bang for buck as I can pick one up for under 100k.
Regards
Marko
  • Replies 76
http://www.2009gtr.c...-2009-2011.html
Just remember the US MY build is a year ahead of the actual build date. eg. a 2009 GTR is a USDM 2010
I recently bought a new Oct build 2010 GT-R premium in Super Silver. Before the purchase, I had originally looked at 2009 GT-R's with 6-10k kms on the clock, but the low quality MFD screen did my head in, as well as the 2009 being a $110k 2nd hand car without an ipod connector. I also looked at the 2011 because I really wanted blue, but the extra 50k on top of what I paid in the end for my 2010 wasn't justified for a little extra power, and a few chassis changes... So I settled on the 2010, knowing I could spend that $50k that I saved on a 2011, in mods and other stuff down the line :)
In the end, it all depends on what you want to do with the car. I really wanted a GT-R with 3 year warranty, but not the big $$$ of the 2011 (at the time), and the one I found ticked all the boxes.
If you're planning to mod though, maybe the 2009 is the way to go. Get it cheap, then spend the savings on a tranny build, exhaust, intakes and a cobb.
Edited by Wardski
Its pretty simple really
MY12 > MY11 > MY10 > MY09
Most of it is refininement and slight software touchups.
The big change came between the Gen1 cars (MY09/MY10) and Gen2 cars (MY11/MY12)
Gen2 has better suspension than Gen1 and better sound deadening for the cruisers.
Other than that the hardware is pretty much identical.
The above info is priceless! Thanks guys.
I will spend time reading thru that link as it seems comprehensive...in the meantime, did the suspension geometry change or is it just the actual struts?
Sound deadening haha I like noisy cars :)
With regards to the transmission, did they actually upgrade any internal parts or was it just dropping the LC from 4.5k to 3.5k which removed wheel hop and subsequent breakages?
The later models are running slightly more power, how was this achieved? Increased boost level is what ive read in the past...
Steering geometry is changed in MY12
Most of the changes are around damp and spring rates
Transmissions are for the most part identical throughout the series with some tiny tiny changes that you need to measure with a micrometer.
This is the Michael, I can't sell my ADM :(
Stuck between a rock and a hard place.
I'm toying with the idea and I've purposely stayed away from going for a drive in an R35, let alone sit in one.
you want 2010 onwards
and a good 5-7k for the obligatory go fast bits
i forget what cars i had prior to the r35.....and that's not because im losing my memory after turning 30 last month :yes:
Edited by domino_z
What don't u like about the 09?
The '10 is a bit more refined mechanically compared to the '09, plus the MFD has a better screen and USB port for iPod or USB stick playback.
Frequency of '10s having bell housing issues is also reduced, plus you're getting a slightly newer car ;)
From www.gtr2009.com
2011 Changes - Other changes include slightly darker wheel center caps, double clear coat on the front and rear fascias and the addition of rear cooling ducts to improve cooling performance around the rear floor area.
The suspension has been retuned and the rear bushing strengthened to enhance ride comfort while still maintaining the GT-R’s outstanding handling. In addition, auto on/off headlights and speed-sensitive windshield wipers are now standard, along with a USB iPod® interface, DVD playback.
Only a Premium model was available for 2011. Launch control was updated to call LC3.
Edited by Wardski
I would say if you're going to mod the thing for regular track duties then the relatively superficial differences between year models is obviously less of an issue. Buy the 09 and spend the extra on go fast bits. If the track bug bites you will need the cash trust me! If you acquire the car for DD duties you obviously have different priorities which will be satisfied with the newer car. It comes down to this simple choice IMO.
No nav, lower quality mfd
2010 has this stuff too - In addition, auto on/off headlights and speed-sensitive windshield wipers are now standard, along with a USB iPod® interface, DVD playback.
DVD playback is easy to crack to bypass handbrake lockout
such creature comforts aren't really that important, but given a base murano has it all anyway, including auto dimming mirror, auto door locks, auto dipping side mirror for reversing, bixenons, led interior lighting, memory seats etc, the mind boggles as to why it's missing.... and still is
Edited by domino_z
I remember seeing somewhere that to swap the '10 MFD into the '09 is almost impossible. Someone on NAGTROC did it but cost them $6k all up, and then the Nav didn't work... doh.
OUCH!
... leads me to believe getting the '10 (if you can afford the extra coin) is well worth it.
I've noticed other things that Nissan have changed in my '10 and are different to my mates '09. Things like the interior fitment being a bit off in the '09, some plastics have changed for better quality ones such as the the black strips either side of the front windscreen which had a tendency to discolour, the plastic painted roof covers above the doors have extra securing clips (the '09s had issues with these breaking off if bumped during a wash.), '09s had a tendency to melt the reversing light (not sure why but there's quite a few in the US with this problem), and a host of other little niggles, bits n bobs....
Not saying the 10 is 100% perfect, but it just seems as though Nissan ironed a few things out along the way, making the 10 a better purchase than an 09. The MFD in the 10 is essentially the same as whats used in the 12 which is a plus.. Forgot to mention that I'm biased towards my 10, so.... just saying
:yes:
Edited by Wardski
GTR is a GTR. The difference between years is negligible up to a 2011. A better res screen or auto lights are great and are all improvements, so obviously the later the year the more refined any car will be. But big deal, the car itself is the experience, no matter what year it is you won't be disappointed. These cars are IMO are the king of the roads, which ever year you get be ready for the attention. if you find a 10 for same price as an 09 get it, but don't pay a premium for the privelage, don't be fooled, they're the same car on the road, you won't spend much time looking at the screen. I don't think there is much of a monetary value to it. Buy what your budget accommodates. Colour and condition should be paramount over minor improvements. if your budget restricts buy an on and spend the difference on a mid pipe, Cobb, intakes and tune, the rest is not relevant. Just my 2c coz u asked
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
