Thinking Of Buying An R35...key Differences Between My09, 10, 11 & 12?
Wardski sounds like your R35 is a garage queen, let me know you're ready to offload it. :P
Indeed it is. I only do 4,000kms a year, nothing but the best treatment for my baby :) Unfortunately I plan to keep this one for at least 5 years :D
  • Replies 76
Is it possible to crack 400awkw's with the DBA's on 98/100PULP - didn't get get slightly bigger turbos then CBA's?
No mechanical differences other than slightly larger turbo inlet pipes. Only the spec v had different turbos
The oem power gain has been in the tuning, so you'll get less of a power increase aftermarket tuning a DBA vs CBA and end up at the same place
Aftermarket turbo inlet pipes are larger than oem
Like I said earlier, a number on a dyno is somewhat arbitrary. Tweak the dyno and you can get it to read whatever you want
Edited by domino_z
i personally dislike the 35,
while it did impress me at first, then i found out how the entire car is a "throw away item"
(my personal experience working on these)
09, 10 have a shim over bucket cam follwer, 11 & 12 have a solid 1 piece bucket with a stem on the inside
the 09/10 cylinder heads IMO are better as you can get shims made up and generally you order them thicker for the intention to grind them to suit the clearance you want
the 11 & 12 you will need to have nissan make up the solid buckets to suit the valve protrusion, if you get the measurement 100% perfect and matches their measuring tools
the bores are plasma coated, cannot be rebored or even honed as the coating is only 2 thou thick, darton will be releasing a sleeve kit quite soon
cranks cant be ground either due to their coating, spin a bearing, buy a new crank
Is it true the bores have to be inspected at 100,000klm's?
if its not broke dont fix it, but by time anyone get to 100,000kms im sure darton would have the sleeve kits available so these engines have more then one life
Sheesh...the R35 is such a shitbox..Im gunna sell mine and buy an 80s skyline
at the same token, this is very good feedback as I have broken my fair share of engines in the past
such an intelligent response, "speedah"
to correct and educate you; (this requires reading the entire post)
never did i say the r35 was a shit box, i was quite impressed with them at first and the "porche killer" nickname and the nurburgring lap time, aka far from a shit box
My workshop has had quite a few come in, and from there i noticed they are the perfect symbol for todays throw away lifestyle. The customer spending a large amount of money to buy the car initially, then something goes wrong or sometime in the future the motor could do with a rebore cause its a tired motor, but there is barely anything that can be repaired, just replaced, so more money goes to purchase of new parts or motors and the rest ends up in land fill,
in short IMO great for nissans profits, bad for consumers wallets
to add in my earlier post not once did i suggest, encourage or talk up "an 80s skyline" or any other type of vehicle, this post was and still will be in reference to the r35 and i was just stating my personal experience with these motors to help Marko R1 make his decision which im assuming this thread was started to list the pros and cons of each of the series
(similar idea when purchasing my r31, i got all the pros and cons, with the knowledge i found i bought a 31 knowing that the cylinder heads crack, leaking power steering racks being a factory option, whinning diffs etc but i still bought it cause "i heart box")
Lol yea 35's are ghey long live the r31
And now the trolls come waltzing in..
Long live the R31 - in a museum.. LOL.. Hmmm, the R31 interior is no better than a same year Mazda 323 as well as being more a dinosaur than Godzilla.
Pity this thread has gone way off topic.... My 2cents - every car has issues, but I wouldn't trade my 2010 GT-R for anything on this planet, especially any of those overpriced euros....
Edited by Wardski
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
