  • Replies 55
Depends on the controller.
Because you can, obviously. It's also cheaper and he has multiple other drives for backup capacity.
Please link to these 'people'.
Ummm, no.
The difference between say 200Mb/sec and 300Mb/sec (the difference between a single SSD sand 2x SSDs in a RAID0) is irrelevant to gaming/home user.
In a server, yeah, great, but for gaming/browsing/photoshopping etc there would be no discernible difference in performance.
There's evidence out there, Whirlpool is a great source.
Ok so doing some number crunching - going with a 750W PSU instead :)
Enermax Platimax 750W EPM750AWT
As most PSU's are most efficient @ 50% load - i'll be nicely inbetween 350-450W which is a nice sweet spot, and saves a bit of cashola (around $40)
I'm still debating the Sandisk vs Samsung SSD route as there is another $70 or so there as well which gets the build back to around $1770 and isn't too bad at all for what should be a very solid PC for another 4 years
Just dropped the hammer.
Changed to a Corsair AX750 and a Sandisc SSD
$1738
Should have it up and running by next week as I'm (waiting for my Technet renewal to go through. Plus I'm too busy the next 3-4 days to do it, just need to get the parts here first.
Noice.
As soon as my tax return hits, I'm ordering a Catleap and going to go grab another 6950 and Crossfire it with my current one.
I can't wait to see Beef 3 on 2560x1440 *drool*
Stupid CPU cooler hits one ram stick LOL
f**k...
Just running stock Inter cooler for now and no overclocking. Will workout what im gonna do next week.
Otherwise all good - will also do SSD next week as well
As i said earlier - I'm not convinced of the Corsair items when using an external fan controller. People have been reporting issues when doing so and I'm not at all keen on having to pull the case out/cover off each time I want to adjust the fan speed. It shouldn't have the fan controller on the actual heatsink, it's a fken stupid idea really
Hrm... I will get the H100 if anything as I've got a case that has dual fans for exhaust and also a good mount point for a dual radiator area.
I'll do more researching.
Time being though it's nice and zippy with the SSD and sits around 4ghz without much drama and heat
$1738
$1738 for whole system?
Yeah I put it together myself the other day, took me maybe 60mins :)
The issue is the air cooler didn't fit as I've gone into... Depends if you want to overclock or not. I'm not sold on what action I'm going to take (swap the ram or change cooler). I'll ponder it for a week or two longer.
For the price - it's blisteringly fast and great for gaming. Huge improvement over my 4yo setup... I'd also expect this setup to stand the test of time and go another 4 years without needing an upgrade other than changing video card every 18 months or so :thumbsup:
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
