Hey guys. I know what I am doing when it comes to cars but I dont know everything. So any input is a great help
The car is a 180sx running a s15 NA (non autech) sr20 with all the original s13 turbo gear. Loom ecu, inj, maf, etc etc.
Basically ive been stuffing around with the factory maf etc to get the tune to run safe on e85.
Standard compression and 6psi of boost from a r33 gtst turbo.
I run a 2:1 ratio of E85 and 98. This is why its difficult to work out correct afr. I guess it runs about E50 and that means it should need about 10-15% extra fuel than normal 98. Also the afr will read different as its calibrated for petrol.
On a PETROL calibrated wideband O2 I get the following readings and it drives 100%.
WOT above 4k (on boost): 10.2 - 11.4
WOT between 2k and 3.5k : 12.5 - 13.1
Accelerating half throttle (max 1 psi boost) : 13.2 - 14
Cruising 5% : 14 - 15.3
Where is it dangerous? Is it bad to run rich on E85? Some say it can cause knocking...
Any info is much appreciated!
Im mainly after safety and thought the lower EGT would definitely help with this high comp turbo setup. As long as rich is ok/safe I am happy and I guess if its lean when off boost im not to fussed as na sr20s dont seem to blow up from cruisng around a bit lean...
Most ecu's will add up to 10-15% based on the stock o2 reading, I have seen up to 50% ethanol run fine in a factory car. If the afr's on your wideband look good you should be fine, as long as the injectors aren't at 100%...
Yeah well it all looks good to me and the difference in engine bay heat after a thrash is a lot lower. Getting a slight rattle at 1500-1950rpm on 30% throttle but ti should eb too bad with no boost
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
