Hey guyz,
anyone know if it is possible to fit 2 10" subs in the boot?
i checked a few subs online that come with boxes and the measurements all look too big.
they are all about 38cm high and i dont think it will fit.
anyone managed to fit 2 subs in?
Pics?
Cheers.
https://www.sau.com.au/forums/topic/404274-subwoofer-in-boot/
I haven't been in the high end car stereo scene for about 10 years. But JL Audio used to make great subs. Dual 8ohm voice coils, wired in parallel drops the unit to 4 ohms. Then wire two of them in parallel for a 2 ohm box. Run if off a big alpine V12 amp.
jaycar amps have always proved themselves...
ive had dramas with jaycar woofers tho... all have let go of voice coils... without overpowering.
VDO dayton woofers and Jaycar amps were the best combination ive heard in a sedan.
whatever you do, make sure everything is power matched, and the box is tuned. cables can never be too thick in gauge.
ive got some oldschool basic box design programs i can throw on a disc if anyone is interested
Thanx for the reply guyz, appreciate it.
i currently have a soundstream stealth 700wrms @ 2ohm amp waiting to go in the boot and that is why i am finding it difficult to get subs to match.
maybe i will check out alberts.
You can do what I've go done (only one side though), a custom side mount box for both sides if you want two subs, but the subs is best to be ten inches (you might get away with twelve inches but less space) and you will have to remove or relocate your jack.
Edited by 81gSKy
OK maybe someone can explain this ohm thing to me.
I have the following amp which is rated 700watts RMS at 2ohms and 1200watts RMS at 1 ohm
http://www.elite-ele...roducts_id=1318
And i found the following sub that may fit in my boot. but it is 500watts RMS at 4 ohms.
http://www.elite-electronics.com.au/index.php?main_page=product_info&cPath=79_123_128&products_id=570
Will this do? i am not after loud music, i just want clean bass at low levels and once in a high level.
Or this sub which is a 600 Watts RMS at 1 ohm.
http://www.elite-electronics.com.au/index.php?main_page=product_info&cPath=79_123_128&products_id=1429
Cheers guyz.
Edited by SL33K
Wow that looks awesome 81gSKy
How much would that cost? i am not good with tools.
I'm not either, best to order it from the States cause they already have them made from moulds, instead of some guy doing it for the first time fiddling around. It pretty much slots in, plug and play, have a look on eBay or other V35 or G35 related sites and forums. Last time I saw it was about $350 each side, there's some fibreglass work as well hence the price.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
