Gday guys trying to trouble shoot, my alarm/immobiser.
The M80g has been fitted to run with my external HKS timer. If i dont use the timer or wait for it to turn off then it works properly (immobilises/alarms)
However i turn on the turbo timer, i get out it still runs and i can lock the doors and once the car has finished running it will turn off and immobilise but it wont arm the alarm, the remote doesnt beep.
As i didnt install it i dont know if its a feature i need to enable or its been wired wrong.
Cheers
Patrick
read the booklet. I have the m60s and whil playing with it, mine locks and immobilises when turbo timer time has finished. Besides, its wank, just disable it.
Been reading the book, AND if you had a genuine Manual like i do you will find it actually says if you got 100kph to let the car idle for 30sec or if 100kph and slopes or +100kph to let the car idle for 1 minute.
No need to get a big head about it. Its hard to sit in the car for 30 seconds
Cool story brosef, the immobilser has the ability to interface with an external timer, was after solution not your opinion, ttys xoxo
  • Like 1
So i guess my real question is, how do you programme the alarm to interface and arm with the external timer, the booklet i received and pdf i got off mongoose do not clarify this.
cheers
Okay problem SOLVED!
If you have a 2012 plus models does not with programming!
If it has been wired correctly donwloading the pdf directly from the mongoose website. Have the car locked and unlock it, with drivers door open quickly turn key in ignition 15 times "as fast as possible" and then turn back to ACC. Count the beeps to make sure you got 15, then if so press button one. Wait ten seconds for a three chirp confirmitory. Kick over car with timer on and try locking it holding down button one, if it locks with a beep you will have success!
Edited by Pattey21
Why would you run the HKS turbo timer when the M80G already has one. That's like noob step number 1.
you must know everything, ill come staight to you next time. Externals timers are more user friendly as you dont have to re-programme it everytime you want to change timer duration.
Cool story hansel. :P
I think people need to start realising that when you come on a forum that you will get mixed responses from vast community/background/age group of forum users.
But seriously, good for you figuring it out. So does it lock and re imobilise the engine when the timer has run out?
Have you sat in the car and tested it? Does the car switch off and imobilise when the door is opened while the timer is running?
haha. Yeah it works and arms properly now. Its stupid how the books doesnt include the programming from 2012 onwards. It mentions the features but advises to contact installer to do any.
it was removed for a reason. those units are sold in 3 countries and NZ did not want it in there.
I too remove T'timers. makes the car entirely too easy to steal.
and before you even think of giving me a serve do a search on who I am :)
Jebus?
your just a big D@#K head thats who you are......kidding.
Thats actually a really good point just bridge the igntion it at the timer plug and either roll start or tap into starter and your away. something ill have to think about
Is there something i can do to make it harder to steal besides hiding/ attempting to armour the wiring?
Edited by Pattey21
good at making friends aren't you :)
in short - piss the timer off and sit in the car for the extra 30 sec. 30 sec out of your life isn't going to hurt you.
mind you I could probably still take the car anyway. most people dont give a rats about alarm install so its probably very obvious and easily bypassed..
My mate who installed it is a electronics tech and before use to be in the trade of doing alarm installs so its proabably well hidden. However in saying that he neglected to tell me the issue of a timer compramising security.
Thanks for the info Chris i appreciate it
Edited by Pattey21
*Thread hijack
So would this mean that my security is compromised since my turbo timer (which I actually use as a boost gauge) is still in the car, Chris?
Or was there something done to the wiring to make it that much harder to steal?
Oh its my turn to shite shir haha Been a while
Your ghey turbo timer is a adr defect ( but I'm sure you dont care!) but it must time how long you wank off ...so the 30 seconds is enough to cool off ? or set for 1 min so the oil has time to cool off and not stick to your palms
But its good to know your master mind fixed it " gold star to you "
In the future ask questions with some respect to the ones trying to help you ffs or expect a ban stick off SAU
A lot of people on SAU have skills well beyond what you could even imagine and help people in need if asked polite !! instead they could say FU pay someone to fix it !!
So chill out
Even if you dont agree show some respect for your fellow sau members
End rant , waits for bitchfest so the ban stick can come out
The question is a nissan is a soft target ( crime in japan isnt rampant like here) multi layered approach to security and even a 10 buck club will slow them down and stop joy riders
Gps tracker is a must on any decent cars and even that isnt a magic fix
Common sense is one major prevention of theft
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
