Gday guys trying to trouble shoot, my alarm/immobiser.
The M80g has been fitted to run with my external HKS timer. If i dont use the timer or wait for it to turn off then it works properly (immobilises/alarms)
However i turn on the turbo timer, i get out it still runs and i can lock the doors and once the car has finished running it will turn off and immobilise but it wont arm the alarm, the remote doesnt beep.
As i didnt install it i dont know if its a feature i need to enable or its been wired wrong.
Cheers
Patrick
read the booklet. I have the m60s and whil playing with it, mine locks and immobilises when turbo timer time has finished. Besides, its wank, just disable it.
Been reading the book, AND if you had a genuine Manual like i do you will find it actually says if you got 100kph to let the car idle for 30sec or if 100kph and slopes or +100kph to let the car idle for 1 minute.
No need to get a big head about it. Its hard to sit in the car for 30 seconds
Cool story brosef, the immobilser has the ability to interface with an external timer, was after solution not your opinion, ttys xoxo
  • Like 1
So i guess my real question is, how do you programme the alarm to interface and arm with the external timer, the booklet i received and pdf i got off mongoose do not clarify this.
cheers
Okay problem SOLVED!
If you have a 2012 plus models does not with programming!
If it has been wired correctly donwloading the pdf directly from the mongoose website. Have the car locked and unlock it, with drivers door open quickly turn key in ignition 15 times "as fast as possible" and then turn back to ACC. Count the beeps to make sure you got 15, then if so press button one. Wait ten seconds for a three chirp confirmitory. Kick over car with timer on and try locking it holding down button one, if it locks with a beep you will have success!
Edited by Pattey21
Why would you run the HKS turbo timer when the M80G already has one. That's like noob step number 1.
you must know everything, ill come staight to you next time. Externals timers are more user friendly as you dont have to re-programme it everytime you want to change timer duration.
Cool story hansel. :P
I think people need to start realising that when you come on a forum that you will get mixed responses from vast community/background/age group of forum users.
But seriously, good for you figuring it out. So does it lock and re imobilise the engine when the timer has run out?
Have you sat in the car and tested it? Does the car switch off and imobilise when the door is opened while the timer is running?
haha. Yeah it works and arms properly now. Its stupid how the books doesnt include the programming from 2012 onwards. It mentions the features but advises to contact installer to do any.
it was removed for a reason. those units are sold in 3 countries and NZ did not want it in there.
I too remove T'timers. makes the car entirely too easy to steal.
and before you even think of giving me a serve do a search on who I am :)
Jebus?
your just a big D@#K head thats who you are......kidding.
Thats actually a really good point just bridge the igntion it at the timer plug and either roll start or tap into starter and your away. something ill have to think about
Is there something i can do to make it harder to steal besides hiding/ attempting to armour the wiring?
Edited by Pattey21
good at making friends aren't you :)
in short - piss the timer off and sit in the car for the extra 30 sec. 30 sec out of your life isn't going to hurt you.
mind you I could probably still take the car anyway. most people dont give a rats about alarm install so its probably very obvious and easily bypassed..
My mate who installed it is a electronics tech and before use to be in the trade of doing alarm installs so its proabably well hidden. However in saying that he neglected to tell me the issue of a timer compramising security.
Thanks for the info Chris i appreciate it
Edited by Pattey21
*Thread hijack
So would this mean that my security is compromised since my turbo timer (which I actually use as a boost gauge) is still in the car, Chris?
Or was there something done to the wiring to make it that much harder to steal?
Oh its my turn to shite shir haha Been a while
Your ghey turbo timer is a adr defect ( but I'm sure you dont care!) but it must time how long you wank off ...so the 30 seconds is enough to cool off ? or set for 1 min so the oil has time to cool off and not stick to your palms
But its good to know your master mind fixed it " gold star to you "
In the future ask questions with some respect to the ones trying to help you ffs or expect a ban stick off SAU
A lot of people on SAU have skills well beyond what you could even imagine and help people in need if asked polite !! instead they could say FU pay someone to fix it !!
So chill out
Even if you dont agree show some respect for your fellow sau members
End rant , waits for bitchfest so the ban stick can come out
The question is a nissan is a soft target ( crime in japan isnt rampant like here) multi layered approach to security and even a 10 buck club will slow them down and stop joy riders
Gps tracker is a must on any decent cars and even that isnt a magic fix
Common sense is one major prevention of theft
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
