Hi there
Im hoping someone here on the forum can help me, coming up to tax time im gathering up ideas on what i can buy for my stagea this year round, i think ive narrowed it down to getting a front lip, eye lids and selling my current wheels and upgrading to work eurolines!
but im stuck, where in sydney can i buy a lower front lip and eye lids like pictured on the black stagea below? ive attatched a photo of my silver stagea aswell so if you happen to see me driving around livo/campbelltown area your more than welcome to stop me for a chat as im always interested in meeting like minded enthusiasts!
By shedmonster_z at 2012-07-11
By shedmonster_z at 2012-04-13
The 25G did not have a front lip and you cant just get a Stagea lip and fit as the main bars are different. You would have to get a complete bar with lip
and they are getting scarce. I would go for an after market like Aero/Dolphin etc.especially if you want/have an FMIC.
Wonder if an R33 GT-R lip is close-ish?
Chris, your best shot straight up would be sourcing a series 1 Dayz/late series 1 kit, which would get the same front bar, skirts, rear bar (minus the black lip) as SWAGON there.
Wouldnt a lip for a skyline been a closer fit??
You'd be surprised how well this lip fits, it does take a bit of play to get it perfect, but it stumps everyone when they realise how difficult it is to get a stagea lip. a skyline lip may have been a closer fit, but again, this one fit surprisingly well.
And yes, i do have a dayz kit, its all genuine plastic, although im not sure if non-days models have the clips available in the sills to mount the days skirts, someone should be able to clear that up though.
  • 4 weeks later...
you wouldnt happen to be also floating around the Casula area would you ?
a few people that i have told i have a S1 have asked if i am "that silver stagea around the livo/casula area" but mines white :)
yours is quite nice!!
i have the same lip as you but no skirts or rear, is this the way they came out??
  • 5 weeks later...
Yep thats me! but moved out raby way a few weeks back, honestly i didnt think many people would have taken notice it looks too plain in silver
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
